Rising Sun Member Forums (http://www.risingsun4x4club.org/forum2/index.php)
-   General Tech Forum (http://www.risingsun4x4club.org/forum2/forumdisplay.php?f=17)
-   -   Anyone else need a new FJ40 hardtop Gel coat? (http://www.risingsun4x4club.org/forum2/showthread.php?t=21401)
frontrange 06-04-2014 10:09 PM
I just had to order 48 oz of opaque white gel coat to redo my top. That's probably enough to redo a dozen fiberglass hardtops. I have a big ass rotary compressor and air tools so if any of the rest of you need a re-shoot of gel coat on your tops - this is your chance.
I've used this material for my pond liner in the past and it has a good 2-3 hour pot life, so I could easily see getting quite a few tops done on one mix. I'm just south of Monument, LMK if you want to get in on the shoot... No Charge, just provide your own labor and dust mask.
baja1d 06-05-2014 06:49 AM
I'm interested, I'll look into the prep work today
AHorseThief 06-05-2014 09:12 AM
I might be interested depending on timing. When were you looking at getting this done?
frontrange 06-05-2014 10:21 AM
Likely next weekend..
akingf5371 06-05-2014 12:25 PM
Man, I would jump on this in a heartbeat if the color was cyngus white... :(
Bruiser 06-06-2014 05:37 PM
I may be interested too. Like Travis I will have to see what the prep looks like and if I can get it done in time.
Sent from my DROID RAZR using Tapatalk
frontrange 06-06-2014 07:04 PM
FYI, if your gutter has rivets that pulled through or you just want to pull it off to fix rust I have the correct aviation rivets and the tool to install them, you'll just need to fix the fiberglass first where they pull through. I already did this on my top a while back.
This is a good sealer to fix a repaired gutter, took me two tubes.
http://www.adventurerv.net/c10-flow-...te-p-3243.html
