Old 04-01-2009, 03:46 PM
isotel's Avatar
isotel isotel is offline
dont Be afraid of the weight.. Its the Lowest and Most Centered part of the truck, so weight is less of a concern.. I under Built mine with 1/8th" steel and ive hammered it enough to the point that i need to rebuild it because its rubbing now on my Transmission pan.
1976 FJ40 TBI350 700R4 Dana300
Colorado Land Cruisers
CrAwLoRadO.com
Old 04-01-2009, 03:52 PM
So true. I went with a 3/16" front skid and went cheap (I rationalized it was to save 15 lbs) with 0.120" for the belly pan. Rubithon made extremely quick work of the thin plate... All unsupported skid plates (if there is no structural frame behind it) I have come to believe must be 3/16".
Old 04-01-2009, 05:56 PM
isotel's Avatar
mine even had inner Support!
Live and Learn
i should have Listened To Bustanutly
http://forum.ih8mud.com/hardcore-cor...ml#post1969646
CrAwLoRadO.com
Old 04-01-2009, 06:15 PM
Rezarf's Avatar
Rezarf Rezarf is offline
I have a 40 skid in the garage if you want it. Factory, needs a little hammering. Free to good home.
Drew
Rezarf <><
K0RZF
My rig... "Maude"
