While many were down having fun in Ouray, I decided that since I was stuck at home I should make the most of my Labor Day holiday weekend
- There was a lot of labor involved ![]() First off, after the GTR I decided that I REALLLY needed to try and get my winch issue resolved - having a non-functional winch when needed is like having an unloaded gun when someone breaks into your home...I know nothing about winches really so I've been putting this off forever. Well, I'm for doing so now because the problem was an easy fix, once I found the problem!One of the little ground wire leads under the control box was resting on one of the cross bars that run between the solenoids. The wire has melted slightly and was creating a short. Another wire was close to the same fate. So, I rerouted all of the little wires diffently and sealed up the damaged wire and voila the winch started working normally - So much for Warn's technical support being sure the issue was the winch remote itself which prompted me to buy a new remote ($70) that had zero impact on the problem ![]() I still have to put the rope back on and wind it on under load and then all should be well! After that success I decided to tackle my aux fan install...Sort of wishing I hadn't after day II of working on it but it is done now and it even works ...Here is a link to the installation write up that I posted on MUD (linky) if you are interested in the full details...On a side note, take a look at my tranny cooler. That thing is pretty well beat up - 12+ years of rocks, bugs, etc. have done a number on that...I checked into the cost to replace it with new. You might want to sit down...$343 give or take . Dang thing must be plated with gold on the inside. For comparison I believe a new Toyota brass radiator for the engine runs $450 or so. Crazy!Finally, although I installed this a couple weeks ago, I wanted to post up my bling-bling Nakman bezel with battery monitor and LED mic holder. This thing is the shizz ![]() . I wanted to get to my FT-8800 install but ran out of time...Maybe I'll get to that this weekend or next. Should be a breeze compared to the aux fan ![]()
Jeff Z. (the "not quite as skinny" one) TLCA #17037 '97 LX450 - aka "The Whale" '97 FZJ80 Antique Sage AE #267, stock 12/74 FJ40, 2F, SM420, 4" Lift, ARBs, 33" MTRs : ![]() "...anything else i can do for you guys, how about i wash your car or mow your lawn while you figure out your firewall system? I am now boarderline insane/unibomber." Kipper "That assumes I'm even capable of pulling and stabbing..." Jacket "I really like having a detachable unit." Beater |
Very nice Jeff! I commend you on the fan install especially! Hooking it up to the pressure switch is the correct way and you will be pleased with your extra work for years to come! You do not need a manual switch!
KØUBN Matt is 2 cooool! Kevin is me! TLCA #3007 Way North of Centennial, CO Stay on the Trail! '64 FJ-40 (Wildrice) - Everything works! ![]() ![]() ![]() '97 40th Anniversary FZJ80 (Ricecake) - Everything! ![]() Quote:
Very nice work, but not all of us were having fun wheeling. That is for another thread.
Thanks T aka Tom TLCA #6136 85 4runner Marlin Ultimate 5" lift 37" MTR's Soft top and doors Towed to Moab by the Big Blue Whale , 07.5 Dodge Mega Cab Laramie 4" lift covered and chiped No more slow lane for me
Ken Romer - K0ROM 97 LX450 Supercharged, Locked, Lifted, Armored and some other toys 06 4Runner 2003 Z4 BMW Roadster ![]() 2005 Horizon Adventure Trailer |
- I tell you this, there were several times during the install that I wish I had just gone the JDM fan route. Looks like that install based on your writeup I read (sans wiring) was my kind of simple.
Jeff Z. (the "not quite as skinny" one) TLCA #17037 '97 LX450 - aka "The Whale" '97 FZJ80 Antique Sage AE #267, stock 12/74 FJ40, 2F, SM420, 4" Lift, ARBs, 33" MTRs : ![]() "...anything else i can do for you guys, how about i wash your car or mow your lawn while you figure out your firewall system? I am now boarderline insane/unibomber." Kipper "That assumes I'm even capable of pulling and stabbing..." Jacket "I really like having a detachable unit." Beater Last edited by corsair23; 09-09-2009 at 01:57 PM. |
I daisy chained mine with the pressure switch and a Thermo switch in the upper water neck. I did that so the fan would not come on in the winter when the defroster was running and the engine is still cold. It turns on by itself whenever underhood temps are high and/or the A/C is on and the engine is at op temps. It continues to run after the key is off until the A/C pressure backs off when the refrigerant has shed the heat. The A/C blows cold right off the get go on a hot start! Being anal about wiring I made a harness that uses the stock un-used CDS fan relay and fuse in the underhood power distribution box. I kept the idiot in the drivers seat out of the equation as the system should work when it needs it, not when I remember to use it!
Congrats on all of this -- especially getting your winch fixed!
Matt Farr, Centennial, Colorado | Webmaster: Rising Sun + Webmaster: TLCA.org 1981 FJ40 "The Hulk" + 1996 FZJ80 "Mayor McCheese" · TLCA #4189 · WØRDY www.rustybrain.com/cruisers · my Rising Sun bio · Facebook If you think you can or think you can't, you're right. "Then again I'm just a goober." - Dave Armbruster "Too late for me then, I'm already disturbed." - Red_Chili "Kipper is a celebrity and you're lucky to get a glimpse of him!" - Uncle Ben |
Like Matt and Kevin said on getting your winch fixed
| Thread Tools | |
