Old 03-03-2010, 09:20 AM
waggoner5's Avatar
Thats cool stuff now. I need one of those thingys.
Old 03-03-2010, 09:36 AM
Looks like Northern has them pretty cheap....http://www.northerntool.com/webapp/w...2876_200342876
I think I got mine from Rigid. I have an account so I'll check on a quantity buy....would make great meeting raffle prizes! It appears the one from Northern is not rated....the ones from Riged are....
Old 03-03-2010, 09:40 AM
They have spec on the Northern Tool...
Additional Specs
* R (Ford) hook has 25,000-lb. breaking strength and 8333-lb. working load limit
* T (GM/Chrysler) hook has 16,000-lb. breaking strength and 5333-lb. working load limit
* J (Foreign) hook has 12,000-lb. breaking strength and 4000-lb. working load limit
I also understand where you're coming from UB. I have an old tow strap, one of the Wal-Mart decapitator specials with the hooks, that I carry for rigging misc stuff if I help someone without recovery points.
Old 03-03-2010, 10:32 AM
I got my cluster hooks from AW direct. I've given away 2 sets, leaving me with just one.
http://www.awdirect.com/cm-grade-70-...k-93169/hooks/
KD0FDS
Stephen
Old 03-03-2010, 10:34 AM
Count me as interested
Dave, my suggestion is to run the honking hook with gate that came off the M15K and call it good...You'll probably always be carrying a D-ring with you that you could swap to if desired. I've read good and bad about the self locking hooks, the bad being that they have a tendency to lock so tight you can't get them to release
If you aren't gonna run the BIG hook with gate, I'd gladly take it back and throw it on the M8274 that is on the 40
Old 03-03-2010, 11:42 AM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
Count me in on a "Group Buy" if there is one! Very nice.
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
