Old 06-04-2010, 02:34 PM
rhyary's Avatar
rhyary rhyary is offline
Dave,
Thanks for your explanation but I need to convert this to specifics:
Bare with me:
1. my bumper is connected with bolts to the frame. Is this good enough RF grounding?
2. In front, I have heavy duty grounding 2/0 and 1/0 from both of my batteries to the engine block and to the fender. These are DC grounding, but is it also good for RF grounding?
3.I also have a 2/0 grounding in from the transfer case to the frame to assist the puny ground cable the 80 has between the body and the transmission/transfer case.
4. The swing arm is on a bearings and I presume it may not be as well connected to the bumper as I would want. So I can see how a grounding strap can help.
5. Bracket I am thinking will be securely attached to the swing. Should I but a grounding strap between the bracket and the swing?
6. up on the "shelf", see my red line in the picture, I presume I will use a grounding strap between the antenna and the shelf.
To all, I have read the existing solutions and may go with those solution. But for this thread if you bear with me and help me figure out the bracket I outlined in the OP it will be super wonderful.
Rami
96 LX450
Albany, NY
http://bestcamptable.com/
KD2KDK
Old 06-04-2010, 03:13 PM
Originally Posted by rhyary View Post
Dave,
Bare with me:
Without testing it you can't say absolutely, but probably not ideal. You have to picture that a capacitor is just two conductors with significant length parallel held electrically insulated by a dielectric. IOW, two painted or powdercoated chunks of steel in close proximity are pretty much exactly a capacitor.
When you put bolts (particularly smaller diameter ones) through, which are generally fairly poor RF conductors because of corrosion mostly, all you are doing is making one huge capacitor into a few just big ones wired in parallel, which is not different in magnitude than the one huge one (caps work electrically opposite to resistors and inductors, parallel is additive, series is subtractive).
What the braid does is provide a good path to alternating current (e.g. RF) that shorts the capacitor(s) and so no charge can build up, negating the bulk of the parasitic reactance. If you poked enough holes and filled them with bolts you would start to make the connection better for RF, but the ultimate goal would be to have a few tens of bolts, which would impact the connections mechanical strength and look bad to boot. You might also be able to make it work if you used unfinished stainless and aluminum with dielectric grease because the materials and bolts would make much better contact. But paint and rust and road grime all impact the path very negatively.
Despite their size and low DC resistance, these cables are generally not good RF grounds and so it is generally good practice to put a heavy braid parallel to the cables from the battery negative to the frame and block.
I would parallel that but for VHF/UHF and particularly for FM it's overkill to go crazy. But you really need to provide at least one solid RF tie for the battery negative, frame and block so that any grounds that tie into them have a good chance of making it home to the radio.
You want a good RF path from the antenna mount to the RF ground. The antenna wants to couple to the mount and anything close to the feedpoint is lower in impedance than things farther away. If you float it relative to it's desired return path you make the system more complicated electrically. That means that you might be able to get it to tune but the more stray reactance you have the more sensitive it will be to changes like rust and weather.
You want to use grounding braid between significant pieces of metal if there is any question of conductivity. What is significant changes the closer to the radiating element, too. An 8" plate under the antenna whip is very significant, while an 8" plate on your front bumper with the antenna on the back isn't critical.
Old 06-04-2010, 03:18 PM
Rami
np.. that red line just doesn't look all that stable...
Old 06-08-2010, 07:28 AM
rhyary's Avatar
Dave,
Wish I could understand everything you wrote. I will at some point, but not yet.
What I have taken from it is that the grounding on my car is good for DC but not good enough for RF.
So my first step is to improve grounding for RF. Would love to have you comments:
Tin copper strap 1" by .062 from here:
http://www.gacopper.com/images/Braid...rg-1GC-Txt.jpg
and here:
http://www.gacopper.com/Braid.html
If understood you correctly:
1. I will add strap the negative of both batteries in parallel to the DC wire to fender, engine block.
2. strap the front and rear bumper to the chassis.
3. Strap the swing arm to the bumper.
4. Strap the transmission to the chassis (may be overkill)
I know I have a good DC grounding. But this will also give me a good RF grounding. Correct?
Can I use the bolts and that hold the bumpers to the chassis?
or do I need to drill holes specifically to the strap?
Looking forward to your comments
Rami
96 LX450
Albany, NY
KD2KDK
Old 06-08-2010, 07:53 AM
That braid is fine, use the widest that is practical and easy to work with. No need to drill extra holes if existing holes line up. You don't need to swiss cheese your frame, just make sure the existing holes are clean and maybe use a bit of dielectric grease or silicone to keep them from rusting too much.
Old 06-08-2010, 07:58 AM
rhyary's Avatar
Any issue with using existing bolts that hold the bumper to the frame under the car?
96 LX450
Albany, NY
KD2KDK
Old 06-08-2010, 08:15 AM
Using existing bolts is OK as long as the braid itself has good contact to the frame or steel and you are not using the bolt as the conduction path. That's the point, to make various pieces of steel all at the same RF level. You do accomplish some of this by using DC grounds and so something is better than nothing for the most part. However all small wire grounds show some sort of odd behavior at different frequencies and even RF braid will start to have odd characteristics depending on size (width, number of wires, etc.) and quality of connections at some frequency. You can only do the best you can, so just get the easy stuff to start.
Old 06-08-2010, 08:25 AM
rhyary's Avatar
So I will have to grind the paint/powdercoat so the strap itself will make conductive contact with the metal. Hmm, rust comes to mind. Also, is it importand for the strap to be short?
96 LX450
Albany, NY
KD2KDK
Old 06-08-2010, 08:45 AM
Yup, yup and yup. The rust issue is major from both the truck and radio viewpoints (rust some place is often why a good install goes bad). You obviously don't want to go to all this trouble to make a clean install to only have your frame and body start rusting away, so you do need to balance the technical need for a good connection against ruining your truck.
As far as removing paint, scuff it to expose some bare metal and when you clamp down the braid it will hopefully contact as much as possible. This is where I use the dielectrical grease. Another option is to paint back over the connection or glop it with silicone or wipe grease on top of it periodically. I use dielectric grease under and all over the connection and periodically clean and re-do. Anti-seize with copper is a good rust preventer and stays around better than dielectric grease. There are probably paints that conduct, but IME powdercoat is pretty lousy conductor and I've gotten a mild RF burn from a poorly ground antenna that could not couple across powdercoat.
Braid, like all grounds and powers for that matter, should be long enough to make the connection without being mechanically stressed. Longer doesn't help you at all with feedlines for power or RF. There are specific reason why you'd want specific lengths, but for anything we are talking about here you want everything just long enough.
Literally everything about a mobile radio installation is a compromise, so you work with whatcha got. IMVHO you should definitely put braid in the locations on the bumper around the antennas and maybe a couple to make sure the body of the truck connects to the frame and the one from the battery to the frame. You only expose a handful of spots to corrosion and you keep it manageable.
Old 06-08-2010, 08:55 AM
rhyary's Avatar
I like anti-seize. I use it everywhere.
The reason I asked about the length is that the negative from the battery to the engine block will be close to 2 feet. otherwise, most straps can be about 8 inches.
PS, I hate compromises :-)
96 LX450
Albany, NY
KD2KDK
