Old 06-26-2010, 12:52 PM
Gator1's Avatar
Gator1 Gator1 is offline
Default 74 fj40 electrical
My Fj40 is having some weird elect problems.
intermittently lose the whole guage cluster... just cuts out but comes back,
some lights in the cluster (high beam, left turn sig indicator, illumination lights) don't work or only work sometimes. looks like the whole back plate of the instr cluster is some kind of circuit board that the bulbs connect with.
and my guage lights and horn seem to come on only sometimes.
power at the fuse block and I put in all new fuses.
wierd how horn/guage lights seem to go out and back together.
anyone with an old fJ have similar kind of probs? tips? suggestions?
Doug
Old 06-26-2010, 01:31 PM
Chris's Avatar
Chris Chris is offline
Check your grounds.
Old 06-26-2010, 04:13 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Don't just check your grounds. Unbolt them and clean them then put them back. Also any loose connection will cause this problem. Typically the battery + & - but also wiring harness connections anywere in the car. If your having several items go out at the same time. Locate that connection either + or - and wiggle it to see I they go out. And work your way back from the lights twords the battery
TLCA # 20314
Step by Step Bed Bob
Old 06-26-2010, 05:23 PM
ttubb's Avatar
ttubb ttubb is offline
X2 - You will find this and fix it! T
KA7TLT - TLCA 13015
Old 06-27-2010, 06:52 PM
Gator1's Avatar
grounds grounds grounds... Most electrical is original. this is gonna be fun. thank god it is a simple vehicle. lots of room.
Old 06-27-2010, 07:01 PM
treerootCO's Avatar
I had similar issues. Clean the grounds for sure but mine was caused by two things. OEM fuses that were old. I could pull on each end and they would come apart. The second was the fuses were replaced but the tabs were corroded. Cleaned the tabs that hold the fuse and it all worked again.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 07-19-2010, 07:47 AM
Gator1's Avatar
isolated and replaced horn regulator... Original part was bad.
Now to figure out the guage cluster...
cleaned every ground I could find, I think now it is all about the back of the cluster,not sure how to deal with that...
Really want it all to work ;-)
Old 07-19-2010, 09:53 AM
Be sure to pull the battery wire before you pull the instrument cluster - lest you short the ammeter lugs against the chassis and have free fireworks in the dash.
You can use a .22 cal bronze brush, in a drill, to clean your fuse contacts on an FJ40. I heartily agree with removing each fuse, being sure the metal caps aren't loose, and cleaning the fuse sockets, tightening them if necessary by bending the contacts.
Old 07-19-2010, 09:57 AM
Default So true
[quote=SteveH;155906]Be sure to pull the battery wire before you pull the instrument cluster - lest you short the ammeter lugs against the chassis and have free fireworks in the dash. QUOTE]
Just did that. I had to have it powered to test things....just butter-fingered it and hit the chasis. damn.
Old 07-19-2010, 11:06 AM
me three. Fixed the fuel gauge, but fried the Ammeter in the process.
