Old 07-19-2010, 12:09 PM
timmbuck2's Avatar
Default strange noise
So Amber is heading to the east coast for a few weeks, and driving the 80 with our 2 girls. Yes, she is crazy, but this is not about that. I am doing a ton of maintenance to prepare her 80 for the trip, and I am stuck figuring out a front end noise. At very low speeds, under 10mph, the front wheels make a light screeching scraping sound, almost like the brake pads are worn out, but I pulled both front wheels and the pads are good. Any clues as to what may be going on? Worst case, I can send her in my 80, but with bigger tires and a lift will cause worse gas mileage, and also means no wheeling for me while she is gone! (other than the 40's only run...)
Thanks all!
Timm
* 00 LC
* 99 Saab Convertible
* 76 Piggie
* 1996 T-100 with 396k miles
has a 2008 FJC
KDěTIM
Old 07-19-2010, 01:56 PM
Going straight, does the noise change or go away if you turn the wheel gently to one or both sides? If it truly sounds like brake sounds that might indicate the wheel bearings are loose, letting the rotor move a little between the pads.
Old 07-19-2010, 04:35 PM
RockRunner's Avatar
If you push on the brake peddle barely does the sound go away?
Thanks T aka Tom KR0MPS
TLCA #6136
Old 07-19-2010, 04:53 PM
timmbuck2's Avatar
Not sure, will check tonight.
The brake pedal seems to not affect the noise at all
* 00 LC
* 76 Piggie
has a 2008 FJC
KDěTIM
Old 07-19-2010, 05:06 PM
Are there any markings on the rotor itself that would indicate the pad is rubbing in a non-uniform way? Does the sound increase/decrease with speed?
I like Dave's wheel bearing guess, or in my case a similar noise was a seized caliper piston rubbing on the rotor.
Old 07-19-2010, 05:07 PM
How about a bent dust shield? A rock between the rotor and dust shield?
Old 07-20-2010, 03:00 PM
TIMZTOY's Avatar
TIMZTOY TIMZTOY is offline
Jack up all 4 corners and have her go 10mph while your under it listening!!
It might be a backing plate. If its rotational like A wheel bearing The noise will increase with speed and typically do it all the time. Not just at 10. Same with backing plate. And knowing women it's been doing this for months. And she never said anything
TLCA # 20314
Step by Step Bed Bob
Old 07-22-2010, 10:02 AM
timmbuck2's Avatar
ok, had some time to work on it last night, still not sure what is going on
took some time to drive it, and the noise is more like a squeaky spring than anything at slow speeds. from 5-15mph is becomes a rotational sound that increases with speed, and is faster than the wheels, so I am leaning towards a driveshaft issue.
jacked up the front end, did the wheel bearing test (grabeed it at 12 o'clock and 6 o'clock and pushed and pulled) and there was little to no movement. I spun the wheels as quick as I could, and there was NO noise anywhere. I pulled the wheels and looked at the brakes again, and all looked good. spun the wheels again and listened very closely to the brake pads and barely heard anything at all.
lubed up both driveshafts, did not seem to affect the noise at all. except the noise is not here in reverse, or is much much quieter. not sure if this happened because of the driveshaft lube or not, Amber said she first noticed the noise in reverse.
so now what? anybody had a squeaky driveshaft before? (yeah, that will end up in a sig somewhere...) I might get a center diff switch from Slee and then yank the front driveshaft to see if it is the issue. might not be a bad idea to leave it off anyway if she is going to be putting 4000+ miles on the truck in the next month...
thanks everyone...
* 00 LC
* 76 Piggie
has a 2008 FJC
KDěTIM
Old 07-22-2010, 11:23 AM
TIMZTOY's Avatar
jack up all 4 tires off the ground, and have her drive 5-15 mph and you crawl under the car listening for the noise. youll find it !!!!! we do this at work all the time
TLCA # 20314
Old 07-22-2010, 11:46 AM
Man, that scares me to death. I bet you guys have a lift that would prevent the truck from falling no matter what. Jack stands don't seem quite as reliable, especially when you're putting all that torque on them.
Another thought: pull 1 driveshaft, engage center diff, drive it. Still hear the noise? Put the first one back in, pull the second one. If the noise goes away, you have found the culprit.
1996 FZJ80 Ě TLCA #4189 Ě WěRDY
www.rustybrain.com/cruisers Ě my Rising Sun bio Ě Facebook Ě Twitter Ě LinkedIn Ě Need satellite Internet? Check out: Exede Internet
