Old 08-02-2010, 07:58 PM
Default t-case output/pinion nut size?
Anybody know the t-case output/pinion nut size for, say, a 1977 FJ40? I think a 1 1/8" socket will work, but I don't know if that means it's a loose 28mm or a tight 29mm.
Old 08-02-2010, 09:35 PM
leiniesred leiniesred is online now
27mm (I have Dr. Schleg's 40's rear diff on the bench right now.)
that would make it a pretty loose 1 1/8th and a very very tight 1 1/16th
KD0FDS
Stephen
Old 08-02-2010, 10:06 PM
RockRunner's Avatar
Rudes is correct, took it apart 4 times and I have it engrained now
Matt where do you live, you can use mine if you want.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 08-02-2010, 10:10 PM
Just curious, thanks though Tom
Just thinking to add to my tool collection a little bit...I need a 54mm hub socket too...hmm...
Old 08-03-2010, 11:46 AM
Tom the t-case output is 27, right? pinion nuts are 32.
I bought a pretty cheap set of HF impact sockets a while back, they've got one that goes up to 32mm I think. They're pretty decent 6-pointers.. most of them are kicking around in the toolbox at home but the 24, 27, and 32 are definitely in the trail bag.
Old 08-03-2010, 01:27 PM
And 46 mm for the crank pulley nut (since we're brainstorming sockets for the tool collection....)
Old 08-03-2010, 08:01 PM
Tim, maybe your 80 is different than my 40 but I'm pretty sure the pinion and t-case output are the same on my 40.
