  #21
Old 07-29-2010, 12:28 PM
TJ, what windshield wipers did you use that fit on the OEM FJ40 wiper arms? Jeep ones are too small....
Great job BTW!
  #22
Old 07-29-2010, 02:09 PM
PabloCruise's Avatar
Great job BTW!
I just source the replacement listing at NAPA, I think it is an 11" blade...
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
  #23
Old 07-29-2010, 03:14 PM
That is correct. For some reason, Carquest and Checker both list 12", which is too long. Plus neither of them stock the blade with the correct mounting clip.
  #24
Old 07-29-2010, 03:16 PM
timmbuck2's Avatar
The good news is I think I can mock this process up on another 40 and get pics of that.
I would like to do an article for the Trails!
so you will be one of our experts for the "party"? you get extra beer and BBQ.
probably should plan this for fall? summer seems pretty busy for most people right now...
* 00 LC
* 99 Saab Convertible
* 76 Piggie
* 1996 T-100 with 396k miles
has a 2008 FJC
KDěTIM
  #25
Old 08-02-2010, 12:48 PM
Put me down as a definite maybe!
Let me know what dates you pick in the fall.
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
  #26
Old 08-25-2010, 08:40 AM
Default Reviving this thread, briefly
Reviving this thread - to remove an intact windshield (for repainting) - do you remove it from the inside-out, or the outside in?
I'm going to peel up the gasket and push the glass and gasket out of the frame together, but I'm not sure which side to go from. Logic would tell you to do it from the inside out, but I wanted to see what others have done.
Thanks!
Thanks - Steve
  #27
Old 08-25-2010, 10:27 AM
Thanks!
Thanks - Steve
Never done that (removal of good glass including worrying about keeping it good), but I would guess removal is opposite of install. IOW, glass goes outward along with gasket, as you wrote.
  #28
Old 08-25-2010, 10:32 AM
x2- I think it would be real hard or next to impossible without breaking the glass to pull the gasket inside since it's way thicker on the outside
WěREK
  #29
Old 08-25-2010, 11:24 AM
I removed my glass by pushing from the inside to the outside, however the glass was in much worse shape when I was done with the removal!
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
  #30
Old 08-25-2010, 12:46 PM
Thanks all! I realize I may break it, but the WS has only one tiny chip, so I'd rather not.
I'm using the most high-tech glass tools - plastic bicycle tire-levers and screwdrivers. The gasket flexes (during removal attempts) about as easily on one side as the other.
