Old 08-29-2006, 05:36 PM
arthog arthog is offline
Default Ohm ?
I need a new fuel sending unite. I have that big ass 50gal fuel troff from Man-A-Fre, they don't make it or supply a replacement sender any more. I found one on summit that says Ohm range 240 Ohms empty and 33 Ohms full. and that leads me to my question. what is, or where would I find the Ohms range for my 55.
Old 08-30-2006, 06:30 AM
The Toyota manual should have the resistance range listed for testing the OE unit.
Old 08-30-2006, 11:02 AM
the Toyota body & chassis manual just tell me how to remove and install. the Haynes manual says 17 +- 2.1 ohms at its lowest flot setting. This does not say what the full setting should be. So I don't know a range to look for
Old 08-30-2006, 11:14 AM
I would assume 55's use the same senders and guages as 40's. I will swing by the shop and test a 40 sender and let you know what it reads.
KE
Old 08-30-2006, 11:18 AM
------------------------THIS JUST IN-------------------------
I found yet another Toyota manual. This one has the ****!
in chart form and everything.
float position-------------------------resistance in Ohms
Full 17 +- 2.1(this is oppitset of the Haynes
manual)
1/2 40 +- 4.5
empty 120 +- 6.5
so do I find something that is exact to that range or do I have a +- on this too.
I don't understand much about resistance. I know a little about the French Resistance but I don't remember them fighting the Ohms they fought the Germans.
