  #681
Old 09-20-2010, 11:04 AM
Disappointing
Originally Posted by treerootCO View Post
The cargo area is stupid bright now.
If anyone needs emergency surgery on the trail, they can use your 80 as an operating room.
  #682
Old 09-20-2010, 12:07 PM
just beautiful, Mike.
  #683
Old 09-20-2010, 03:08 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
From my house it looked like the Mile Hi Stadium lights were on.
Is that "48 LED SMT Array" a plug in bulb? Better interior LED lighting would be a huge plus for me and those seemed to be selling for a very reasonable $24.99.
  #684
Old 09-20-2010, 06:08 PM
treerootCO's Avatar
Event Coordinator
It comes with the 31mm festoon. I popped 4 of them before I realized the new version isn't protected from reverse polarity. Silly diode.... Just make sure you match the red wire side with the positive.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
  #685
Old 09-26-2010, 01:21 PM
Snowrun's Avatar
Snowrun Snowrun is offline
This is the low pressure power steering hose that let go on the trail. I ordered part number 44412-28160 from Toyota, approximately $25. The Cruiser part is discontinued but the Previa is a close match and rated for ATF. The web also says the line is 10mm not 3/8" but I don't know if that makes any difference.
Attachment 16448
This is the hole that caused the issues....
Attachment 16449
Thanks for posting the part number seeing as I have now had the exact same failure in the exact same spot on the hose.
I think this might be something others should put on their 80 series PM list.
'94 FZJ-80 Locked
'99 LX 470
TLCA#21035
My Cruiser videos on Youtube
  #686
Old 12-28-2010, 07:59 PM
treerootCO's Avatar
Event Coordinator
Re-welded the upper pan-hard rod mount. The hole had egged itself out and was starting to make awful clunking noises.
www.root45.com
TLCA #14133
  #687
Old 12-28-2010, 10:51 PM
coax's Avatar
coax coax is offline
What kind of welder did you use to do the work? I've got a low-speed cluck that I am pretty sure is the rear panhard. Hoping its just the bushing and no welding necessary, but I really don't feel like digging into it while its cold out. Nice job!
-Corey
'74 project pig (sold)
  #688
Old 12-29-2010, 08:12 AM
treerootCO's Avatar
Event Coordinator
It is a Miller 175, 220volt, wire feed mig. Must have left the tank on because the shielding gas was all gone. That always makes overhead welding fun with solid wire. I was able to get the drill in from the back to redrill the holes. You couldn't tell by looking at the hole either but the bolt had about an 1/8 inch play in all directions front and back.
www.root45.com
TLCA #14133
  #689
Old 12-29-2010, 03:29 PM
I also get some god awful noises from below. Maybe it's time to buy a new bolt, cut off the old one and take a look
  #690
Old 12-30-2010, 11:45 AM
Inukshuk's Avatar
Could this be the source of a low-temperature clunk I get?
