  #21
Old 04-04-2011, 09:23 AM
I didn't because it looked like it was just gounding the case, and in my installation the screws that hold it down go to the body...
But, if on yours it just screws to the wooden box it might be a good idea now that you mention it. I bet some regular copper wire that you have left over from the basement might work fine since the main ground is what carries the power. It's probably a safety thing and maybe it doesn't affect the normal operation of the thing that much? I bet Dave knows
  #22
Old 04-04-2011, 09:26 AM
Alright I may as well, and yes I've got some 12ga copper that would be great for this, I'll loop it under to the back and attach to the 4ga that runs under the truck to the frame.
  #23
Old 04-04-2011, 11:35 AM
That's funny - I forgot to ground my case too. Mine is mounted to wood, so I probably should at some point....
