Old 09-11-2011, 09:40 PM
L43dean L43dean is offline
Default Putting the Cruiser back right
Dean, if you could save that for me for a few more days I'll pick it up from you after work this week after work
you got it!
Old 09-15-2011, 10:09 PM
It worked!
Thanks to Dean, I was able to procure a replacement firewall bracket. I swapped it out tonight, then went for a drive. The pedal feel totally changed, and now I could feel the break where there's more resistance and I'm getting into the secondary. I could feel a quicker acceleration, and it didn't run out of wind at about 3000 rpm, it just kept pulling. After jumping on the highway and going up an exit, I pulled over and popped the hood. The paper clip on the secondary actuator shaft had moved! For the first time ever since I have owned this 40! Why didn't I discover this sooner!?
So I took it down to Ricardo's test track, aka Surrey Ridge. I hit the bottom of Surrey Ridge at 3000 rpm (about 65 mph), and once I was on the incline I floored it. Fairly quickly the rpm crept up to just under 3500 rpm (about 76 mph), then slowly bled off on the upper portion, getting down to about 3250 rpm (about 71 mph) before the road leveled off again. Since my speedo is broken that's the best I could get for now. I did those calcs based on 30" tires, since my 31x10.50 MT/Rs are worn and I'm not sure what diameter they started life with.
Not a huge difference, but I have more available power than ever before, and it certainly pulled that hill better than it ever has! I can't wait for the I-70 hillclimb next weekend on the way to the Argentine Cleanup!
Now, I wonder how many 2Fs have been ditched for V8s because of a similar problem?
Rising Sun Bio
Old 09-16-2011, 07:59 AM
RicardoJM's Avatar
Most excellent Matt.
Ricardo Maestas - Bio Page
KD0CAW
1999 LX 470
SOLD - 1971 FJ-40
TLCA #18941
Old 09-16-2011, 09:38 AM
Matt - I used a paperclip on the secondary actuator when I rebuilt the carb on my '78, back in, um, 1991. I have a kit, and you may have given me the inspiration to rebuild the carb again - or at least do the paperclip test - and then do a rebuild. I wish there were a more robust way to test a 2F carb secondary, but I've never found one.
Thanks for posting your results!
Old 09-16-2011, 09:53 AM
I'll race ya!
Old 09-16-2011, 10:19 AM
If it works, it works
The first problem for me was getting the primary to travel far enough to move the stop so the secondary would be allowed to turn. I was able to determine that with the engine off, by hand. Once I got that figured out, the rest fell into place.
I'll race ya!
You're on! Ricardo and Martin, you better watch out too!
Rising Sun Bio
Old 09-16-2011, 10:54 AM
AHorseThief's Avatar
AHorseThief AHorseThief is offline
FJ40 drag races. Maybe we can get some sponsors and head up to Banimere. I'm sure tons of people would pay to see that.
Nick Kimball
'73 FJ40 Rockin a 327 SBC
Old 09-16-2011, 11:39 AM
arthog arthog is offline
A new event for the rally. DRAG RACES!!!!!! 4 wheel burn out contest. smokem if you can.
Old 09-16-2011, 11:54 AM
I've got the smallest motor in my 40 than anyone...can I play? Mines even just a 1 barrel and an auto to boot!
Colorado Trail Patrol
Stay on the Trail!
Old 09-16-2011, 01:36 PM
sure
Rising Sun Bio
