  #41
Old 03-12-2012, 02:15 PM
my personal preference is to use modifiers like MMC or LMC. some people think that makes it more confusing.
  #42
Old 03-12-2012, 02:25 PM
GD&T has nothing to do with this, at least not with what I'm asking...
What I'm asking is more analagous to 2F vs. 3B vs. 2UZ-FE...
  #43
RFS - Racing Four Stroke (or regardless of feature size), single cam motor
LC4 - newer twin cam motor
FCR - Keihin carb, at least 3 different sizes: 37, 39, and 41 mm throat diameter
  #44
Old 03-12-2012, 02:39 PM
I was messing around
  #45
I think the smaller new-generation 4-strokes are RC4. My dad's 530 has an LC4. Both his and mine are 2008. And it sounds like Tim has the same RC4 as I do, which means that the RC4 started in 2007?
EDIT: Marco - me too, that's why I had to throw in the GD&T acronym as well...
  #46
Old 03-12-2012, 03:32 PM
RC4 it is then, got it!
and it's been a while, but I used to have CQE after my name.
  #47
Old 03-12-2012, 03:44 PM
Tim, Mine says RC4 right on the case. Doesn't yours?
  #48
Old 03-12-2012, 05:01 PM
Found another good read for how to set these carbs up http://www.thumperfaq.com/jetting.htm it's for WR's, but same carb.
  #49
Old 03-13-2012, 08:12 AM
Beater's Avatar
Beater Beater is offline
that's a good read, but I'm telling you, all you will ever need is the jd spreadsheet once you baseline the carb.
john (johnny) henley
  #50
Old 03-15-2012, 11:34 PM
Yes it does, ok RC4 for sure then.
I received my new parts from JD, the new washer, o-ring screw for the fuel screw, and the #42 pilot jet. Draining my tank tonight, will work on washing it out tomorrow night and saturday, then diving into the rest of the cleaning.
If anyone likes searching for fasteners, the washer for the fuel screw is .200" OD, .120" ID, and .020" thick.
