Old 03-18-2012, 10:27 AM
Saturday Daniel lead Stephen Rudy, Steve Powers and myself out to Wipe Out Hill. I had not been out there since my first CM. It was a great day despite the wind and weather beginning to turn for the worse.
We stopped at the Overlook and Tusher Tunnel before heading out towards Wipe Out Hill.
Old 03-18-2012, 10:38 AM
Wipe Out Hill.
Old 03-18-2012, 10:48 AM
Daniel took us out to a small slot canyon near the end of the run. Kids had a great time with that.
Old 03-18-2012, 10:58 AM
The Durango folks bugged out last night as the weather was certain to get worse before morning. A dry tent is much nicer to pack than a wet one in the morning.
Thanks for everyone who organized and attended, I had a great weekend. It was great to meet some new faces from the Book Cliffs club and I learned some spotting techniques for varies obstacles.
Old 03-18-2012, 12:15 PM
Air Randy's Avatar
Corbet, I assume you found your tube doors OK?
I noticed that the only pictures of Meanie you posted are the ones where you were driving it .
Meanie is turning out to be like an amusement park ride, everyone takes turns in it to do Hell's Gate. It does make it pretty easy
Meanie managed to make it up the Escalator too with nothing but rookie spotters. Had 1 minor wheel stand on the last wall, backed down a few feet, re-adjusted and walked the rest of the way up. Jade Runner made it up too albeit with a little more excitement and (wait for it) a manual strap for safety. But, he made it without a scratch and lots of vehicles never make that obstacle.
JonHaris took some amazing photos and videos on both Hells Gate and Escalator. Can't wait for him to post those up.
The mighty meanie had it's first trail breakdown later in the day about 2 miles in to Metal Masher. The steering felt funky so I stopped and checked it, 3 of the 4 high steer knuckle bolts on the drivers side were sheared off and missing.
We jacked the rig up, pulled the wheel, used Steve Brady's drill to drill a hole in to each stub, hammered the tapered end of a large file in to each hole and unscrewed the broken pieces. Fortunately I had some 1/2-20 bolts that would thread into the knuckle though they were 2"-3" too long. So we stacked nuts and washers on them to make up for the slack. Looked like hell but worked just fine. I have 2 sets of ARP chrome moly knuckles studs ordered and on the way, that should minimize breakage in the future.
I suspect the knuckle studs may have loosened up on that side. I was too busy doing wrenching sessions to check them my bad.
Then, driving back to camp going up the long grade on 191 to BFE, the tranny started to slip a little in 3rd gear. So, now I need to drop the tranny/tcase before CM. The TH400 has a direct drive clutch pack that is the most likely villain, probably just a seal going bad thats letting the line pressure to that clutch pack drop.
Oh, I noticed one of the Fox air shocks in the rear is leaking oil so I guess I'm going to have to re-build that too. Oh well, if you play you have to pay
Old 03-18-2012, 03:34 PM
Randy look close at the first picture of Meanie. Your driving, you can see Buddy in your lap. But I'll post some more for you. And thanks again for the transport of the tube doors. Got them just fine.
Old 03-18-2012, 06:12 PM
Trapper50cal's Avatar
Trapper50cal Trapper50cal is offline
That Porter solo shot with the rock walls is an amazing shot...
Old 03-18-2012, 07:31 PM
Air Randy's Avatar
Whew, I thought for a minute there you were borrowing my dog too . Just yankin' your chain, I think we need to build you a Meanie like rig too. You seem to enjoy it it quite a bit.
Old 03-18-2012, 10:51 PM
Old40Dog's Avatar
Old40Dog Old40Dog is offline
Thanks to everyone who attended and we had a great time!
Zach & I are sitting in the Grand Junction Walmart parking lot as the left front wheel bearing on the 80 is toast. Going to call Hugh at Safari in the AM to get the necessary parts to get'er repaired and home.
Dave K,TLCA#20150,KFDOG,'69 FJ40-"Toyolet",'92 FJ80 {Isuzu diesel conversion underway} ,2011 Replica M416 w/RTT,'98 Taco Xtracab 4X4, Project='72 FJ40, '05 Passat TDI-DD.
Old 03-19-2012, 02:06 AM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Aw crap. And I had some in my parts box.
Did you find the propane bottle?
You would have not wanted to tow the trailer tonight anyway. Snow was bad, chains required on Vail (with a bad jacknifed rig Westbound) and Eisenhower and Eisenhower was closed anyway due to a wreck in the tunnel so we took Loveland Pass.
