Old 04-07-2012, 07:49 PM
Won't you have tranny tunnel issues with this swap? Typical 3spd-4spd stuff? What are you doing about the steering column with no column shifter now? And where did you source a parking brake that will mount to a split case? I thought those were unobtanium...
Old 04-07-2012, 09:15 PM
baja1d's Avatar
baja1d baja1d is offline
Default 3.73's
Originally Posted by Tommy the Cat View Post
I have a set of 3.70s from an '87 FJ60 if you are interested. Just throwing it out there...
Thanks for the offer. I have a set but then got the h55 for a steal. I think I'm going to stick with the 4.11's
Travis Hurley– Owner/ C.E.O.
Old 04-07-2012, 09:28 PM
baja1d's Avatar
Default tunnel
Yes I do believe that I'll have to do some mods to the tunnel but it shouldn't be anything more than what I'd have to do if I were to put a four speed in. As much as I'd like to keep the column shift it's just can't stay. Furthermore, removing the straight column for a tilt column is slightly safer IMHO. In regards to the parking break, they are very difficult to find. I just happen to look at the classifieds on Mud one day and a guy had just listed one that he never installed. It wasn't cheap but eliminated a lot of headache. Having my kids over the last 3 years didn't lend too much time for physical wrenching but I did source a ton of parts, most of them for pennies on the dollar.
Old 04-09-2012, 08:14 AM
baja1d's Avatar
Let the games begin.
1. Breaker Bar...check
2. PB Blaster...check
3. BFH...yep
This was no easy feat for a solo operation and no manual. Started at 4pm after the Easter activities were finished and had it out at midnight.
Old 04-09-2012, 08:40 AM
Make sure to fix that bezel while you have things apart!
Old 04-09-2012, 08:49 AM
baja1d's Avatar
On the list
Old 06-17-2013, 03:41 PM
baja1d's Avatar
Boy, how things have changed. I guess when you live so close to outstanding off-roading and 6 hours from Moab it was inevitable. She's definitely not stock anymore but she is back on the road!!!
This has been a long build with a steep learning curve. Like most, one thing leads to another. I've learned some invaluable lessons along the way; for example, patients, how to fabricate, weld, and ignore naysayers that seem to find their way onto every forum. I've also encountered a few setbacks; i.e., mini or power assist p/s that just wasn't going to cut it and the H55/ unobtainable parking brake drum kit debacle. Let's face it, a 2F and five gears are for sea level but not here in the Rockies!
In addition to setbacks & burnout, we’ve moved once, flipped two houses, and had two kids.... yes; life does continue to go on even when building a 40. Although my wife recently accused me of being more in love with the 40 than her! Yeah, she was really thrilled when, like most Cruiser Heads, I came home with another Landcruiser and proclaimed "that each kid needed one"!!! Fortunately she really digs the “family” aspect of wheeling and the fact that I'm in the garage (often with both kiddos) rather than the local pub.
On that note, we get out a dozen times per year and have made two Cruise Moab rallies, both in the 80. This last trip we wheeled with the infamous Woody and, thanks to JKimmel, definitely came back with some lifelong stories. Rising Sun has been awesome and we've met some incredible people along the way. It’s a sport that has stuck and, therefore, the rig had to match the style. So here's what I’ve done:
-1986 2F motor swap
-Four speed tranny/ split case with Marlin Crawler Box
-4 wheel disc brakes conversion
-SOA with flipped springs and anti-inversion shackles
-Saginaw P/S with GM tilt column
-Cryo'd shafts & Longfields
-FJ60 knuckles
-4x4 Labs hi steer and 6 shooter steering arms
-35's and rear Lockrite
-Family cage with tumble/fold rear seats
-Painless wiring harness
Still to come:
-Front ARB locker
-Bumpers, tubed fenders, and sliders
For those of you that are ready to give up, sell the rig, or even light it on fire; it truly is an incredible feeling to finally drive a “labor of love” and know that you’ve done 95% of the work. I’d relate it to catching a fish on a fly you tied only greasier! All the eye injuries from 49 years of crap falling in them and the countless busted knuckles was worth it!!!
This Wednesday will be her christening. I thought that it would be appropriate to run (Red Cone) the same trail where many of the earlier pictures in this thread where taken; back when she was truly “stock”……..
Thank you to all that helped along the way, Hope you like her.
Travis
Old 06-17-2013, 04:56 PM
OilHammer's Avatar
Sweet! They are fun with the top off, eh?
Been a long time, but what did you do with the 1F? That had a part or two on it that I would be interested in.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
Old 06-17-2013, 04:58 PM
baja1d's Avatar
Treeroot has virtually everything that I took off
Old 06-17-2013, 10:11 PM
Very cool! Nice to see 3 years of work pay off.
