  #31
Old 08-19-2012, 10:59 PM
I'd loan you my leak down tester if I was local. You could probably get one from Summit for less than paying for a test. Same with the pressure tester on the cooling system. But I agree with Gary. If your loosing coolant you need to determine where its going.
  #32
Old 08-20-2012, 08:45 AM
waggoner5's Avatar
Originally Posted by ianacole View Post
Timing at idle only...
Timing at idle only only gives you an initial timing. You have no idea where your total timing including advance really is under load. Although I dont think the timing is the culprit here, it certainly can aggravate an existing cooling problem. After doing a leak down, buy or borrow a dial style timing light and check your total advance. A mild SBC likes between 30-34 degrees total advance. Your coolant loss sounds like the big issue though...
  #33
Old 08-20-2012, 08:54 AM
You state it is a SBC. Is it a 350 or 400 ci?
  #34
Old 08-20-2012, 09:48 AM
ianacole ianacole is offline
Send a message via AIM to ianacole Send a message via MSN to ianacole Send a message via Yahoo to ianacole
It's a 350, "Y" code, from a 75ish G20 Van, as best I can figure out. Next payday I'll get a leak down test. I can do a compression test (I have a tester) in the mean time.
Ian A. Cole
Blue '73 FJ40 - My DD
Blue '06 Tacoma Quad Cab 4x4 longbed - 's DD
  #35
Old 08-20-2012, 10:06 AM
How clean was the old coolant? I ask as the older SB's had a tendency to accumulate all the rust and corrosion from poorly maintained cooling systems around the rear cylinders. Once it builds up it restricts or even closes off coolant flow to the heads at the back port. Not saying this is what's going on but if it is it's really hard to get that crap out. I have seen and dealt with this a few times over my past life as a shop slave. It was really bad with the '60's SBC. The 400 ci has Siamese cylinders (they touch each other so no flow between cylinders) and the heads have steam holes to allow flow which can have many restriction issues.
  #36
Old 08-20-2012, 11:13 AM
And that's ultimately what I wonder is going on. When I pulled the coolant with the first water pump change when the heating issues started it was pretty nasty ... dark brown/blackish.
Ian A. Cole
