Notices
  #21
Old 05-23-2011, 10:30 PM
The 80 has been sitting since Saturday with the fridge running, and I checked it tonight and it still seemed good. Voltage on the battery was 11.4V. I cranked the temperature down to 27* to get the compressor to cycle on, which it did and ran steadily and happily for 5 minutes.
So the problem definitely stems from something in the 12v socket plug setup I had previously. With 14g wire and the Anderson plugs the voltage drop seems to be minimal.
  #22
Old 05-24-2011, 08:07 AM
Will your battery start the 80 on 11.4V?
Looks like a very cool solution!
Rising Sun Bio
  #23
Old 05-24-2011, 08:32 AM
Not sure if it would work with your outlet, but you see the little hole in the middle of the assembled PowerPole? You are supposed to put a tiny roll pin in there to keep the two parts from sliding back.
But if you leave out the roll pin you can thread a small ziptie or a twisted piece of wire through both holes of the mated connector, which keeps them from vibrating apart.
  #24
Old 05-24-2011, 09:04 AM
It's an aux battery, so it's not needed for starting.
Dave - The wall mount came with a roll pin, but the individual connectors I bought are actually bonded together and won't slide.
  #25
Old 05-24-2011, 09:37 AM
Understand, a dab of super glue is good for that. I was thinking along the lines of the fridge plug vibrating out of the bulkhead.
  #26
Old 06-22-2011, 01:12 PM
Dave - were you thinking something like this:
These plugs don't really "lock" together, so I could see there being some risk of separation if excessive vibrations were present.
  #27
Old 12-03-2012, 11:25 AM
Default about to PP the fridge...couple questions...
Hey Matt, I'm about to do this same thing to try to address that crazy RFI coming from my fridge (doing this before looking at grounding inside the fridge).
Questions...
1. did you just cut off the cig lighter end and PP the existing plug that goes to the fridge? Or did you make a whole new 10g jumper?
2. Do I need to figure out Pos/Neg on that existing plug? if so, how?
thanks!
  #28
Old 12-03-2012, 11:43 AM
I used the existing ARB plug and disassembled the 12v male socket plug end, and replaced it with the PP connectors. It's fairly obvious once you open up the socket which wire is which, but as I recall the positive wire runs to the metal tip at the end of the plug and the negative wire joins the side contacts that touch the outside circumference of the female socket.
Making this change is a good move. I fiddled with different 12v sockets and wires for for months trying to solve various problems before changing to the Powerpoles. I haven't given it a single thought since I made the change.
  #29
Old 12-03-2012, 11:55 AM
Default perfect!
thanks!!!!
  #30
Old 12-03-2012, 12:03 PM
I did my fridge with the power poles and it is great.
I replaced the whole wire coming from the board inside the fridge. Probably more than you need to do. Mine is the edgestar so it needed a bit more work. I think the majority of the edgestars complaints stem from the bad power cord and mine has worked perfectly ever since I did the conversion.
