Old 02-05-2013, 12:36 PM
nattybumppo's Avatar
Default Yaesu FT2200
A friend gave me a Yaesu FT-2200 that he didn't want, thinking it was a CB, but isn't it a ham radio? What do I have here...is it worth keeping?
Sascha Steinway TLCA # 20217
2013 F-150 "Black Ops"
Old 02-05-2013, 12:42 PM
http://www.universal-radio.com/catal...rs/ft2200.html
The Yaesu FT-2200 is a compact, full-featured 2 meter mobile transceiver. Despite its diminutive size, it provides RF power out at 5, 25 or 50 watts. 49 Memories are available. Extended receive from 110-180 MHz is featured including the civil air band (118-139 MHz in AM mode). The optional DVS-3 Digital voice unit permits digital voice recording and playback. This radio requires 13.8 VDC at 12 amps. (140x40x160mm 1.25 kg). A backlit DTMF hand mic is supplied.
The Yaesu FT-7200 is similar to the FT-2200 but covers the 430-450 MHz (70 cm) band instead of 2 meters. RF power output is 5, 20 or 35 watts. This radio requires 13.8 VDC at 12 amps.
Clicking through the link above, apparently the FT2900R is the current new model in that line of rigs...It runs $150-$200 it would seem depending on current rebates. Dave can probably give you a better idea of what the FT2200 is worth but maybe $50-$100 if it is in good working shape?
Sounds like a good little radio for a 40 - Someday I plan to put something similar in my 40...
Old 02-05-2013, 01:07 PM
Definitely worth keeping, if you wanted to be a part of the ham world. You're an antenna away from a nice little setup.
Old 02-05-2013, 01:16 PM
RicardoJM's Avatar
Keep it. Get your ticket. Install it in your trail rig. Tune it to 146.460 and enjoy.
Ricardo Maestas - Bio Page
KD0CAW
1999 LX 470
SOLD - 1971 FJ-40
TLCA #18941
Old 02-05-2013, 03:00 PM
Fishy's Avatar
Fishy Fishy is offline
I eyed one of those on Ebay before I bought mine. I think it was going for around $90 with bids on it.
EDIT: It's pretty big, right? With a big heat sink built in?
Stan
UZJ100 (Non-White Edition)
OutdoorX4 Magazine Staff
100s in the Hills Co-Director
Old 02-05-2013, 04:23 PM
It does have the exposed heat sink and IIRC no fan. It's not that big, smaller than a FT-1802 or FT-79/88/8900. About the same size as the current FT-1900 I think. There's not much empty space in the case, it's a very small radio.
Good little radio, worth hanging on to for when you get your ticket. Probably worth $75 to $100 on eBay or eham.com, I'd likely ask about $50 from a friend if it's in nice shape and functions.
I've always thought the guts of the Kenwood TM-241 are probably the same as the FT-2200, although I've never had both at the same time to compare. They seem /very/ similar.
Old 02-05-2013, 05:07 PM
Fishy's Avatar
That sounds fair.....I'll give ya $50 for it!
Stan
Old 02-07-2013, 08:08 PM
Thanks, Stan. But I think I'll keep it! It came with a magnetic antenna, is a hard-mount antenna a better idea?. Maybe I'll just mount it up and listen in on you guys for a while.
Old 02-07-2013, 09:22 PM
Old40Dog's Avatar
Old40Dog Old40Dog is offline
Sascha...your crowding in on the DOG space now you're so da.. lucky....such a a lucky dawg man! Maybe you need to consider changing ur handle on here....to LuckyDawg!
Go for a Diamond NR770HNMO that you can lay down and be done with it. About $70 and you'll never look back!
Dave K,TLCA#20150,KFØDOG,'69 FJ40-"Toyolet",'92 FJ80 {Isuzu diesel conversion underway} ,2011 Replica M416 w/RTT,'98 Taco Xtracab 4X4, Project='72 FJ40, '05 Passat TDI-DD.
Old 02-07-2013, 10:41 PM
Mag mounts are good except for 2 situations, IMO.
The first is pretty unlikely, however the more serious of the two, and that's if you ever stop super abruptly (as in an accident) that antenna could become a foil (fencing term?) and potentially pierce into something ahead of you. Again, unlikely, but a safety thing like bolting down your hi lift.
The second is the exact opposite direction, which is the tendency for tree branches to periodically lower and remove your magnetic antenna. It's almost a guarantee on Slaughterhouse, or one of the other wooded runs, less of an issue on something exposed obviously. But still, can be annoying.
that said, I've got a mag mount that I keep with one of my spare mobile rigs, that roof makes a dang good ground plane and it's a pretty sweet temporary setup. Just not a long term solution, IMO..
