  #21
Old 02-13-2013, 09:22 AM
RicardoJM's Avatar
Originally Posted by Dirt Claude View Post
Glad to hear the new tranny is much smoother. When we had it on the lift last time, I recall Ricardo mentioning that a couple of the bolts on the cross memeber felt like they may have been stripped. Did everything look okay when you tore it apart?
They looked ok (were not cross threaded stripped) and went back in but Jeff did have to work at it. IIRC, the tolerances are tight and the key is to work all 8 bolts evenly. I would think that opening up the holes on the plates just slightly would resolve the issue. The other thing to keep in mind is to note which side is driver (or passenger) as we initially had it opposite. Once we swapped sides it slid right in (from the rear) and fit snug.
Ricardo Maestas - Bio Page
KD0CAW
1999 LX 470
SOLD - 1971 FJ-40
TLCA #18941
  #22
Old 02-13-2013, 09:23 AM
rover67 rover67 is online now
Nice work you guys! Awesome that Randy has it goin' on down there... we are fortunate to have such a generous fellow in the club.
Not sure how I missed the thread.
bummer you had to go back and replace the input shaft bearing... at least it's sweet now!!
  #23
Old 02-13-2013, 10:08 AM
bigcity25's Avatar
The verdict is still out on the clutch. I am waiting to get a phone call today from the shop. I told them about my slave cylinder, lack of return spring and the modification I did to have a return spring. I am not sure if the spring is too heavy and puts too much of a pressure on the slave cylinder. Or the possibility my slave cylinder is bad.
I think the trick to the cross member is to start all the bolts and then snug it down once all the bolts are threaded.
Gotta thank the guys again for all the help and also Justin at redline. I'll be making a trip down there to give him a bunch of free parts.
Jeff Billingsley
Denver Colo
7/70 Fj40
desmogged 2f, 4 speed
TLCA #21898
  #24
Old 02-13-2013, 10:43 AM
Originally Posted by bigcity25 View Post
...I think the trick to the cross member is to start all the bolts and then snug it down once all the bolts are threaded...
That's good practice for most multi-fastener assemblies
  #25
Old 02-13-2013, 11:05 PM
bigcity25's Avatar
Headers on and it's badass. Quiet and no more chocking. The slave cylinder is a different story. I knew my 2f was out of a fj60 and now pretty sure it's a 1986 2f. I have this screwy clutch fork that doesn't have a return spring. When I ordered a slave cylinder I just ordered one for a fj40 4 speed. So long story short the push rod wasn't long enough (story of my life) . The guys at comprehensive auto overcame this and now everything is working fine. That place is a great shop, and prices weren't too bad.
Jeff Billingsley
Denver Colo
7/70 Fj40
TLCA #21898
  #26
Old 02-14-2013, 12:00 PM
So you're fully operational and back to trouble free DD status?
  #27
Old 02-14-2013, 04:30 PM
bigcity25's Avatar
Yep, knock on wood.
Jeff Billingsley
Denver Colo
7/70 Fj40
TLCA #21898
