Old 04-01-2013, 03:21 PM
PabloCruise's Avatar
Ooh, a torch.
Maybe I should bring the piece and we can torch things after the recovery sessions.
Also, in keeping with my compulsion to post pics of everything...
Pic 1 is assembly, pic 2 shows bolt surrounded by roller, pic 3 is how things are supposed to look by now.
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 04-01-2013, 03:36 PM
L43dean L43dean is offline
Got it. A few years back in Trails, Mark Whatley recommended a mix of equal parts ATF, Mineral Spirits, Acetone and Kerosene. I use it to soak parts in a covered container. It works well. Mark said he learned it from person at Ruger.
Old 04-01-2013, 03:42 PM
Ed's Red?
Does it work better than the Aerokroil?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 04-01-2013, 03:55 PM
Originally Posted by PabloCruise View Post
Ed's Red?
I believe Aero Kroil works better.
Old 04-01-2013, 03:57 PM
Thanks for hooking me up, see you Weds at the meeting!
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 04-08-2013, 12:22 PM
I am sure the Aero Kroil helped, but in the end, it was the press that prevailed.
We chucked it up in the press with a 19mm socket to keep the fairlead end plate from deforming. It squeaked and then immediately gave way with very little pressure. But once the bolt pressed flush with the roller, it was stuck again. So out came the punch again. That was fine until the punch slipped and boogered the top two threads... :sigh:
Fix one thing, break another. Seems to be how I am rolling these days...
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
