Old 04-18-2013, 09:06 AM
gahi's Avatar
gahi gahi is offline
Yes. That's the way it was built. Its a PJ trailer
Gary
1996 FZJ80
2000 UZJ100
Old 04-18-2013, 09:13 AM
In that configuration those lynch pins are fuses.
I don't think so. The shear strength of lynch pins depending on size is anywhere from 12-13k to 28K +
Old 04-18-2013, 09:25 AM
True, but remember that pins are rated for double shear yield. It's better than a bolt here, but some being half round do give up cross section. I was just wondering if that was original, it works but seems to me to leave some room for end user error if someone does not replace them with with equivalent.
Old 04-18-2013, 09:37 AM
I like the pin system on the car hauler even tough Dave does not Gives you the ability to adjust the chain length for different vehicles. I always need extra chain for my 4x4 labs bumper as the chain eyelets are up under / behind the bumper.
I also like those chain bolts Dave posted. What sucks down here are my retail resources are so limited. Ordering two speciality bolts online is not cost effective and it pains me to do it. There is one trailer place in the county. See if I can get over there tomorrow.
Old 04-18-2013, 09:42 AM
rover67 rover67 is online now
It also seems that while there would be some shear load on the pins most of the force would go into bending the link over in the event of that chain being yanked.
Old 04-18-2013, 09:44 AM
I'll clarify, the way they did that is fine. If you do it yourself you need to make sure the slot is cut cleanly and just large enough for the link to fit through. If it's a hole, the pin will bend or pull through before the chain link bends. Also, I thought the OEM would put them on leashes so someone can't put undersized fastener in for lost pins.
Old 04-19-2013, 11:46 AM
OilHammer's Avatar
Sometimes I think you guys just like over complicating things for the sport of it.
While not as clean, why not just take the easy route and loop two chains through the "A" of the tonge and connect them via rated hardware? Or are we assuming the tongue triangulation is too far away or ripped off in the accident completely?
I'm not sure why you guys are dogging on quick links, some of them ARE rated and are even supplied by Reese as a product intended for towing.
A rated one:
http://www.homedepot.com/p/Lehigh-35...3S-6/100299638
You rip through two of those, and you likely rolled your truck in the process.
Or, if you REALLY want sturdy, use these: http://www.westmarine.com/webapp/wcs...classNum=50333
You can find those cheaper than west marine, but good lord, 6,500# per link should suffice.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
Old 04-19-2013, 12:00 PM
Oh, I agree. For me I guess is the challenge is to fabricate something that looks super clean and is still as strong or stronger than the standard solutions. So yes there is some sport to it
I used the quick links on my other trailer (3/8") and I'm not against using them, but on this project I'm trying not to. My only complaint is that for any given size the quick link is rated at about half that of the chain(grade 70). I plan to use 5/16" chain so the quick link in this case is rated at 2200lbs. That's a little under the gross trailer weight but with two in the system I should be good if I go that way. Anything will be better than the 1/8" chain that came on the trailer And in addition to the lack of strength my current chains are just too short.
Old 04-19-2013, 02:21 PM
OilHammer's Avatar
Oh, well if we are sporting...
http://www.fmcsa.dot.gov/rules-regul...spx?reg=393.70
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
Old 04-19-2013, 05:56 PM
A rated one:
that seems kinda chinsy
