Old 05-26-2013, 03:17 PM
Keith's Avatar
Keith Keith is offline
Default "System too lean on bank 1" on 99 4Runner
Hey folks. Thought I'd run this by the experts here....
The Check Engine light on my girlfriends '99 4Runner came on 2 days ago. It has not had any driveability problems and seems to still be running just fine. We took it to NAPA and had them read the code and got "System too lean on bank 1".
So, per the recommendations of the folks at NAPA, we put in a can of fuel injector cleaner, and will fill it up with premium next time we fill it up. A web search seems to indicate we might also want to clean or replace the Mass Air Flow (MAF) sensor. So, I'll take a look at that in the next couple days.
Anyone here have any other thoughts on what we should do, or just do those and don't worry about it as long as the light doesn't come back on?
Thanks,
Keith
____________________
05 Double Cab Tacoma
64 FJ40
KEŘITH
Old 05-26-2013, 06:22 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
Clean the MAF. Guaranteed. O'Reilys sells good MAF cleaner.
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
Old 05-26-2013, 06:25 PM
buy the stuff that's labeled MAF cleaner, I think CRC is the brand. Carb cleaner isn't good for them.
KDŘGWX
Old 05-26-2013, 10:17 PM
jps8460's Avatar
jps8460 jps8460 is offline
Commander
check for vacuum leaks. 2nd what Marco said about MAF cleaner.
Old 05-27-2013, 08:20 AM
Firetacoma Firetacoma is offline
As others have said, the chances are excellent it's a dirty MAF sensor. Once it's cleaned, disconnect the battery to make the light go off, if it stays off you're fine.
Also, if it has a k&n oil filter or so etching similar, get rid of it. Those things dump all kinds of oil onto the sensor.
Old 05-27-2013, 09:26 AM
What they said, and if you do put a can of fuel injector cleaner in use "BG44K". NAPA here sells it.
Old 05-27-2013, 10:02 AM
Squishy!'s Avatar
Originally Posted by corbet View Post
use "bg44k
X2
-Justin Morgan,
TLCA #23166
Old 05-27-2013, 02:38 PM
Keith's Avatar
Yup, that's what we used. From our local NAPA.
Thanks again folks! Working all day today and tomorrow. Should be able to clean the MAF sensor tomorrow or the next day.
64 FJ40
KEŘITH
Old 05-27-2013, 05:34 PM
Squishy!'s Avatar
Hey if you want to swing by my place I've got a can of MAF cleaner make it a quick fix.
-Justin Morgan,
TLCA #23166
Old 05-30-2013, 03:00 PM
Keith's Avatar
Finally got to NAPA and bought some MAF sensor cleaner. Man was it ever a pain in the ass to get to the sensor on the 4Runner. Had to take the whole airbox off... And once I got there found that 1 of the 2 screws holding the sensor in place was missing.
Also went ahead and cleaned the MAF sensor on my Taco while I was at it. That was quite a bit easer to get to.
As an update, the light never went back on after we just put in some fuel injector cleaner, but since then I've cleaned the sensor and put in a tank of premium gas. Let's hope this will ward off any evil spirits.
64 FJ40
KEŘITH
