  #81
Old 04-21-2012, 10:09 AM
No gas in the lower tube from the float bowl, looping over the carb now. And it's possible the gas I saw in the upper tube was from twisting the carb to gain access to the jets.. I may be onto something though, I am pretty sure I reset my trip odometer when I topped off up at the dirt track, which means I rode another 39 miles then put 1.1 gallons in yesterday.
  #82
Old 06-03-2013, 09:35 PM
Still have any extra o rings?
  #83
Old 06-03-2013, 09:51 PM
Probably. Can bring the lot to Argentine? You gonna come up and ride a little?
  #84
Old 06-03-2013, 09:53 PM
baja1d's Avatar
baja1d baja1d is offline
Ace Hardware has them. A paper clip also works & last much longer. Better yet, stainless wire or hand grip wire
Travis Hurley– Owner/ C.E.O.
  #85
Old 06-04-2013, 07:23 AM
Won't make it up to Argentine on the bike. Probably going to be doing some last minute wrenching on the 40 in order to make it Sunday. My "problem" may just be my pilot screw, or may just be that the bike hasn't been exercised in a while. I'm doing some more reading on the oring mod...
  #86
Old 06-04-2013, 10:53 AM
Just thinking out loud here but your Tundra seems like the ideal Argentine choice over the 40 this time... lots of bed space for hauling out trash, easily capable of running all of the open roads in that area, plus it can haul a motorcycle. ok will stop now
  #87
Old 06-04-2013, 11:23 AM
Nope. Trees are too tight on the lower road. Don't want (any more) pinstriping.
  #88
Old 06-04-2013, 11:37 AM
Ah, ok. you know there's an app for that
