Old 06-03-2013, 08:05 PM
wyoluke wyoluke is offline
Default Engine Help
My 1969 FJ40 may have thrown at least one rod. It has been a good motor for the last 16 years, but may be in need of a replacement. I guess I am interested in any advice as to whether to rebuild, replace rods, or just go with another engine. I would like to stay with the same motor f145, or go with f155.
Thanks!
Luke
Old 06-04-2013, 07:25 AM
From what I understand, 1F engine parts are hard to come by for a rebuild. I would suggest searching craigslist, IH8MUD, etc. to find a good running 1F as a replacement. Or consider a 2F swap. 2Fs from FJ60s are pretty plentiful right now.
What are your symptoms that make you think it threw a rod?
Old 06-04-2013, 08:37 AM
Heard a loud bang and then it sounded like something was banging against the hood. Had a loud knocking sound. Now though there isn't a knocking sound but I can tell at least 1 or 2 cylinders are down.
Thanks for the info.
Old 06-04-2013, 11:50 PM
I had absolutely no problems whatsoever in getting parts to rebuild my F155 for my 1971 last year. Trying to remember the name - Mile High? They were in Wheat Ridge off of I-70, they used to be Lakewood Auto Machine? Anyway they machined my block, crank and head and sold me a complete kit for my old school F engine, no problems.
Old 06-05-2013, 12:17 AM
simps80's Avatar
simps80 simps80 is offline
Do you remember what they charged by chance for both the parts and machine work?
Mike | KØSMP |
Old 06-05-2013, 12:21 PM
jps8460's Avatar
jps8460 jps8460 is offline
Commander
It sounds like you on your way to a solution. Figured I mention it any way. Doug at Doug's Ballancing in denver is an old timer that knows a lot about this old iron. He did all my machine work fitted my cam bearings and sourced my valve springs guides and seats. He doesn't crank grind in house, but has a local source.
Old 06-05-2013, 07:33 PM
I believe the complete kit was around a grand, included pistons, rings, cam, lifters I forget what else. Obviously bearings, gaskets and seal kit too.
The machine work was to both the block and head, they punched my cylinders a half mm, they had to sleeve one or two of them, that added around $400 IIRC. They ground the cam, and even machined the inside of the rods where the rod bearings go so they were more round.
The head work was fairly extensive, besides decking it to within about 0.030" of the limit they put in Chebbie valves and cut new seats to fit them.
The machine work was about $1,600 IIRC, but like I said, about $400 of that was sleeving a couple cylinders.
They went ahead and installed the new cam bearings for me since that takes an SST most of us don't have, and they were nice enough to R&R all the freeze plugs for me.
Their hot tanking removes all carbon and grease but NOT rust. I was somewhat disappointed at all the surface rust on the exterior cast iron surfaces but they basically said not to worry about that.
