Old 07-05-2013, 09:33 AM
cbmontgo's Avatar
cbmontgo cbmontgo is offline
Default FJ40 clutch question(s)
My project 1979 FJ40 has a new Centerforce clutch...so, I refilled the clutch reservoir and bled out air from the line, but the clutch doesn't do anything when depressed. Also, I can start the engine with the truck in gear and it doesn't "lunge" forward like it should with the clutch out...almost like the clutch is engaged all the time.
Any ideas? Internal clutch workings are unknown to me.
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
Old 07-05-2013, 10:20 AM
RicardoJM's Avatar
Yes, it does sound like the throwout bearing is depressing the fingers enough that it is not allowing the pressure plate to mate the clutch disk to the flywheel. Pull off your inspection cover (you may have to remove skid plate and front driveshaft) and take a look at it. With the clutch disengaged, you should see the clutch fork return spring pulls the fork and throughout bearing away from the fingers so that there is a gap (about 1/8") between the TO bearing and the fingers.
It does seem odd that with the truck in gear, you are able to start the engine and it does not cause the truck to move. Did everything work before you refilled the clutch reservoir?
Ricardo Maestas - Bio Page
KD0CAW
1999 LX 470
SOLD - 1971 FJ-40
TLCA #18941
Old 07-05-2013, 10:31 AM
cbmontgo's Avatar
Thanks, Ricardo. I bought the truck as-is, so I don't know how well it was all put together. Supposedly he had a brand new Centerforce installed when the body was removed and the undercarriage was sandblasted.
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
Old 07-05-2013, 11:13 AM
RicardoJM's Avatar
Originally Posted by cbmontgo View Post
... I don't know how well it was all put together. Supposedly he had a brand new Centerforce installed ...
I've got good news for you Carson - you are going to eliminate the unknowns and will know for sure in short order.
The bad news is that you may end up having to get into it pretty deep. With the symptoms you desribe, the clutch disk may not have been installed.
First things first, remove the inspection cover so you can take a look at what is going on.
KD0CAW
1999 LX 470
SOLD - 1971 FJ-40
TLCA #18941
Old 07-05-2013, 11:32 AM
subzali subzali is online now
I don't know boo about clutches, but have read about installing the clutch disc backwards? Seems like a common mistake? Don't know if it would cause these symptoms...
Old 07-05-2013, 01:01 PM
treerootCO's Avatar
Event Coordinator
clutch slave rod adjusted too far out would disengage the clutch. Same could be said about the clutch master if the rod to the pedal is too tight.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 07-05-2013, 01:11 PM
cbmontgo's Avatar
Could this account for starting the truck in gear and it doesn't "lunge" forward with clutch released?
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
Old 07-05-2013, 01:13 PM
cbmontgo's Avatar
I am starting to think that I don't have time for this rig. May sell.
'76 FJ40
'77 FJ40
'83 HJ47 diesel
'96 FZJ80
'00 UZJ100
TLCA # 14207
