  #41
Old 07-15-2013, 12:28 AM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
I sold my TG's. They seemed to do everything just fine - even though I blew out a sidewall on Chicken Corners at CM 2012 (talk about easy trails) but I never loved them.
I love my Duratracs, from looks to performance. I do worry about sidewalls, not because I think they are weak, but because the design of the tire has a narrower square-edged tread so when aired down they hang over more. On road handling of my 80 is better than ever with the Duratracs. Better than the BFG AT's or TG's.
  #42
Old 07-16-2013, 03:29 PM
X2 on Duratracks - way better than any other tire I have ever had. I'm running the 285/75-16s on my 60.
  #43
Old 07-16-2013, 03:53 PM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Sidewall is important so I thought....I just ripped a sidewall on my Radial TSL Super Swampers on Argentine......would have been sexier on a tough trail.
Anyone know of a tire shop that will do an interior patch on a tire?
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
  #44
Old 07-16-2013, 04:41 PM
DSL might as they do truck tires.
  #45
Old 07-16-2013, 05:37 PM
For the record, I'm going to air down less from now on. 25 in front, 30 in back... on highway I'm more like 45/45. I'm fairly convinced that the DT's get too bulgy when you bring them down closer to 20, particularly in a heavy and loaded wagon.
And ride quality is still ok even at 25 in front, which could be the sole benefit of IFS..
  #46
Old 07-16-2013, 07:21 PM
I kind of did that when I first got mine, but now I have more confidence in the sidewalls, and go 35/35 on road and 20/20 off road. When I was running 45 on road it was kind of harsh. I think these tires are designed to have more sidewall bulge than we are used to seeing in other models of tires. In fact, I used to ding up my rims a lot more with my BFGs than I have with the Duratracs.
  #47
Old 07-16-2013, 09:29 PM
I thought the tgs were ok, better that the bfgs. I'll probably to with duratrac in 100. You guys run some high pressure. I would think 32-35 road and 18-20 off is good
  #48
Old 07-16-2013, 10:17 PM
Inukshuk's Avatar
around 42 road. 18-25 offroad depending if dirt or slickrock. I have gone as high as 50 trying it out and no problem highway, rough in town.
  #49
Old 07-16-2013, 10:45 PM
45 is probably way on high side. Is that hot or cold? You know the tire heats up and will raise the pressure? so when you are at 45 and it heats up it could be as high as 55 or more possibly exceeding the air pressure requirements. you should do air pressure by hot and cold and no than 10% difference and load for HWY driving. Too high a pressure and you hit something the tire can burst.
Beater probably has a lot of good info for thread.
  #50
Old 07-17-2013, 07:50 AM
One of my local GoodYear dealers down here quit selling DT's to the oil/gas guys as they had way too many sidewall problems. I love mine in the winter, the way they look, ride quality etc... But the sidewalls are paper thin compared to anything else I've ever owned. I would assume they have more kevlar or something to get the "E" rating? I've never punctured a sidewall on any tire yet but I do have a couple cuts in my DT's sidewalls from somewhere? And I never wheel them? Where as I abuse my Generals and they show less sidewall wear. I air down to 12-18psi depending on the trail.
But in reality if you find a sharp rock it will probably cut any tire. And most of our trucks see far more pavement than trail. So it can be hard to run a aggressive heavy tire on a DD. I wish I had a 3rd set of wheels for a set of trail tires and could run a mild AT for DD duties. My Generals will be done by the end of this summer. I'm going with Toyo MT's next in all likely hood. That is the preferred tire down here for the oil rigs.
