  #51
Old 07-17-2013, 09:39 AM
I kind of did that when I first got mine, but now I have more confidence in the sidewalls...
And I seem to have swung the other way now, with much less confidence now that I've torn one.
  #52
Old 07-17-2013, 11:20 AM
farnhamstj's Avatar
33psi pavement, 16psi off-pavement. 295.75.r16 BFG AT's
KD0GWO
  #53
Old 07-17-2013, 11:21 AM
coax's Avatar
coax coax is offline
Slightly off topic, but regarding the tire pressure, I believe for an 80:
Originally:
P275/70/16 at 32psi
Load index 114, 2480lbs
De-rated for installation on a light truck/suv = capacity of ~2254lbs.
For an LT285/75/16, at 40psi, is rated to 2340lbs. So, a hair under 40psi is a good starting point to then adjust based on personal preference, load, tire model, etc. If an empty vehicle, a bit lower, if a full vehicle, a bit higher. I typically run mine on the road at 42 PSI with the bumpers, skid plate, winch, RTT, etc.
http://toyotires.com/tires-101/load-...flation-tables
-Corey
'74 project pig (sold)
  #54
Old 07-19-2013, 08:08 PM
NoVaGator NoVaGator is offline
I'm getting a set of Duratracs put on the 100 tomorrow... I'll let you know what I think.
They're replacing a well-worn set of Nitto TGs
  #55
Old 07-20-2013, 02:02 PM
Ok DTs are on.
First impression: brand new DTs are much quieter than mostly worn Nitto TGs.
That was surprising.
  #56
Old 07-20-2013, 08:19 PM
Originally Posted by NoVaGator View Post
Ok DTs are on.
They are amazingly quiet for how aggressive the tread is.
  #57
Old 07-20-2013, 10:05 PM
