Old 01-02-2007, 07:45 PM
Originally Posted by isotel View Post
I had a Dished out Spacer that came with mine.. I Called Shot an e-mail to Aussie locker with photos. He said its just an abnormality with the milling process or some crap like that.. He sent out a new spacer and a free t-shirt.. Now that im thinking about it, i guess the dished out one will work fine.. aslong as the smallest gap is in spec.
That's a load of cr@p. Their manufacturing process does not involve milling number one, and second there's no way any machining process (I've spent a LOT of time running mills and lathes) could possibly come up with those dimensions. If you weren't paying ANY attention the worst you could do would be about .002, not .005. With CNC it would be more like .0005. The problem is with their powder-metal sintering process, not with machining.
In any event, like I wrote, from an engineering standpoint, the parts should operate as-intended with the dimensions written, even if their quality control sucks. I just hope the hardness and tensile strength is properly distributed as the design was intended.
