Old 09-20-2013, 04:05 PM
Default replacing blinker bulb on Sahara bumper. 2 questions.
Changed both bulbs (the 1156 and 5007), the little running light now works, but blinker still doesn't work. (getting the fast blink). I'll clean out the socket tonight, as it's filthy. (fog light works, BTW)
1. Is there supposed to be a seal between the lens and base?
Also, I think I traced the correct wires back to a plug at the center of the valence. everything looks snug...and will test the voltage from there. But are there separate grounds or something else I should check?
thanks!
Old 09-20-2013, 04:22 PM
Caribou Sandstorm's Avatar
You just reminded me I have to replace a bulb on my tail light!
Chris
2001 UZJ100 Mel's rig now!
2016 Tacoma TRD OR DBCSB
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
Old 09-20-2013, 04:54 PM
Fast blink generally means not enough resistance for your flasher to maintain a normal pace... usually indicates either you still have bad bulbs, your good bulbs aren't making a connection, or you tried to go LED? I'm guessing door #2, filthy socket- steel wool, grill brush, whatever you got that's sharp & pokey that'll bust up that rusty dirt.
Old 09-20-2013, 05:13 PM
Default perfect.
thanks Nak. I'm going with Door #2, too. (tutu?) the pad of my finger just wasn't abrasive enough while on my back in the parking garage at work during lunch.
I should be indicating my direction more effictively by tomorrow.
