Old 11-16-2013, 11:51 PM
Brucker Brucker is offline
Draining the fluid
Removing the calipers
Hubs removed
Driver side hub will need to be replaced as it is missing some vital parts, like the springs...
Removed the retaining nuts and washer
Rotors, hubs and wheel bearings removed
Backing plate removed
Spindles removed
Axle shafts and birfs removed
Old 11-16-2013, 11:52 PM
3rd member removed
removed the stock tie rod
Then cut off the steering stabilizer, sway bar mounts, and traction bar mount
And cleaned up the axle housing for the new weld on components:
Painted the backside of the new components
And tack welded the new components in place
Something that is not included in the kit are steering stop reinforcements. And most will tell you they are a must with larger tires and from the abuses shown through wheeling. So we quickly made up some and tacked the into place
With the new weld on components tacked into place, we aligned our axle jig into the housing and commenced welding everything together.
Spring spacer
diff protection
truss
All cleaned up
Old 11-18-2013, 11:06 PM
Disappointing
Wow! This is awesome!
Old 11-18-2013, 11:23 PM
nakman nakman is online now
Incredible. But why did the front spring hangers have to come off? perhaps that will be revealed later... Really impressive, will be sweet to see come together!
Old 11-19-2013, 08:06 AM
J Kimmel J Kimmel is offline
I can't speak for Aaron, but factory hangers are thin and weak. When I put one tons under mine (long before linking it) I did the same thing. Aftermarket hangers are WAY beefier and up to the task of bigger tires, etc
Old 11-19-2013, 12:49 PM
simps80's Avatar
simps80 simps80 is online now
sweet tech thread!
Mike | KØSMP |
Old 11-20-2013, 12:42 AM
Originally Posted by simps80 View Post
sweet tech thread!
Thanks for the kind words. And Jeremy hit the nail on the head when it comes to the factory hangers.
Time to install the hi-steer arms. As they came:
Removed the factory arms along with the shims and studs.
No need to go with upgraded studs as long as the stock ones are in good condition and are properly torqued along with applying a chemical thread locker.
Studs installed with thread locker
Hi-steer arms installed
Old 11-20-2013, 12:43 AM
New loaded 3rd member from Trail gear. I will let the photos speak for themselves:
3rd member installed and sealed:
Prepping axle for paint:
And the axle freshly back out of the paint booth:
And not liking the way one knuckle moved, we double checked our preload set by shims using a scale. Factory manual states it should be set at 15lbs of resistance but we are happy with the 14.5 lbs we have:
