Old 02-11-2014, 01:42 PM
cbmontgo's Avatar
cbmontgo cbmontgo is offline
Default Vacuum on 2F motors...
What are your vacuum readings on well-tuned 2Fs here at elevation?
Old 02-11-2014, 02:27 PM
At 7K feet elevation, 15. maybe 16-16.5 if the barometric pressure is really high (on a nice day). This is on my '78 2F with decent compression. The lower the elevation, the higher the vacuum reading.
Old 02-11-2014, 02:49 PM
cbmontgo's Avatar
That's what I was thinking. I am running at 13.5-14" on one of my 2Fs and was told that I may have an intake manifold leak that is big enough to necesitate additional carb tuning. I also live close to 7,000'. I would think that if a well tuned 2F pulled 20" hg at sea level, then 13-14" at 7,000' is not necessarily indicative of a significant vacuum leak?
Old 02-11-2014, 04:27 PM
kurtnkegger's Avatar
I got this information by googling engine vacuum at elevation...I've understood there would be a 1" drop for every 1000ft of elevation.
When testing manifold vacuum, it’s important to remember that if an engine idles at 22” Hg at sea level, it will idle at about 17” Hg at 5,000’, 14” Hg at 8,000’ and 12” Hg at 10,000’ altitude. Variations from the calculated standard, of course, are the weather conditions, the engine design, and how well the engine management system adjusts spark advance and air/fuel mixture to correspond to a change in barometric pressure.
Old 02-11-2014, 06:12 PM
cbmontgo's Avatar
Yep. That's why it seems that 14" isn't too bad at 7,000'. I just don't want to start replacing manifold gaskets if I don't need to.
Old 02-11-2014, 06:56 PM
subzali subzali is online now
That's about what mine gets at my parents house at 7000 feet
Old 02-11-2014, 08:19 PM
Carson, if this is my old 2f we're talking about, then it was running really well even on the coldest winter days up here at 8000+ feet. You mentioned you took the carb off and rebuilt it due to that hesitation and then it started to run funny. I would look to the last thing you did first. Or, before doubting the manifold, check old vacuum lines, etc.
Old 02-11-2014, 09:11 PM
cbmontgo's Avatar
Hey Martin...it is indeed. Love the rig though.
It idles fine once the engine is at full operating temp, but doesnt hold idle when cold. My stock '76 only needs choke for a minute or two for cold starts. Could it be the aftermarket headers that warm up more slowly because they are more separated from the intake manifold than OEM? I also might have created a leak at the base of the carb with the new gaskets. I also suspected getting something stuck in the idle circuit during the rebuild, but replies to my idle circuit thread on ih8mud suggested a vacuum leak. Who knows. I'll get it dialed in soon.
Anyway, it is fun wrenching nonetheless. I'm just splitting hairs at this point. I'd drive this puppy to Alaska tomorrow if I had the time!
Old 02-11-2014, 10:33 PM
The header with no heat riser absolutely makes a difference. Choke to start then push it in half. a few minutes at least with the choke at 1/2 to 1/4 until warm. I would usually start rolling after a couple of minutes warm-up with the choke 1/4 then open it up all the way once I was down the road. We've had these Butt Cold temps lately too. That 40 spent winters hibernating in the garage. I would get it out for snow runs occasionally and it always started and ran even after sitting weeks in the garage in the cold. It only needed choke in the summer for initial start up.
Old 02-11-2014, 10:42 PM
cbmontgo's Avatar
Sweet. I think my whole issue might be adjusting to the non-stock headers! The low vacuum hypothesis just didn't seem right.
And yes, it has been really cold lately. Not the best time to play with a 2F.
