Old 02-17-2014, 12:47 PM
Default NL intelligent solenoid: where to install on 100 series?
I'm about to take the plunge and start wiring up the dual batts in the LX. I have the Slee tray installed already. I plan to run Aux. into the cabin for a fuse box and one in the engine bay. I also have to plan for a future Air compressor.
Where are you installing that solenoid? just drilled to the top of the slee bracket or vertical on the firewall/fender/under the slee bracket tray shelf?
thanks!
Old 02-17-2014, 06:57 PM
cbmontgo's Avatar
cbmontgo cbmontgo is offline
thanks!
I installed mine on the ps inner fender right next to the second battery. This was for my 80 Series though.
I've been thrilled with my National Luna setup for my fridge and winch. It is the best out there in my opinion.
Old 02-17-2014, 09:35 PM
Mine's drilled to the top of the Slee bracket - that little flat shelf?
Old 02-17-2014, 10:03 PM
cruiseroutfit's Avatar
cruiseroutfit cruiseroutfit is offline
Wasatch Cruisers
I mounted mine on the fender forward of the dual battery:
Kurt Williams
Cruiser Outfitters
Your original outfitter for OME - ARB - AA - Safari - Helton - Engel - Since 1992
Please call or email for pricing, tech, stock check, etc
Join us on Facebook
Old 02-20-2014, 02:44 PM
Default good spot
I think I'm going to put it where you have yours Kurt. Looks like the OEM holes match up??
Question...Did you fuse that short run from Aux Battery to the Solenoid?
Old 02-20-2014, 03:30 PM
Fishy's Avatar
Fishy Fishy is offline
Same....
Stan
UZJ100 (Non-White Edition)
OutdoorX4 Magazine Staff
100s in the Hills Co-Director
