Old 02-23-2014, 12:46 AM
euroford's Avatar
euroford euroford is offline
Default Power steering connections, FJ60
so... trying to reassemble this FJ60 steering system, i think i must be missing something where the lines connect to the steering gear and pump, the fitting are bottoming out and leaked like crazy.
i've just burned an hour of my life googling this, and i think there should be some sort of crush washer or whatnot for the flare fitting to seat against, yeah?
i can't seam to locate much info about this, not a part number or photo or anything. surely one of you guys have gone and lost these things before...
do ya think i'll have any luck at napa tomorrow, or got a better idea?
at any rate, ya'll should know, now that i've swapped cruiser axles, brakes, steering, and master cylinder into my 'jeep', it drives better than at it every has!
Tim M Hovey
1950 cj3a: FJ60 Axles, brakes, and steering, Willy's
sheetmetal and a Buick engine, held together with
metal from the scrap yard glued together in a garage in
Louisville and dragged around behind a F350 Diesel.
Old 02-23-2014, 08:05 AM
ttubb's Avatar
ttubb ttubb is offline
I think pictures of what you are working on would help.
KA7TLT - TLCA 13015
Old 02-23-2014, 08:54 AM
baja1d's Avatar
baja1d baja1d is offline
Yes, pretty sure there are suppose to be crush washers
Travis Hurley Owner/ C.E.O.
Old 02-23-2014, 09:07 AM
Default I could swing by
I'll be running around today at some point (I'm in lafayette). Maybe taking a look at mine would help? I just replaced one of hoses on my 60 with a Napa hose, they had it in stock here in Louisville and was plug and play. (IIRC, NLA from Toyota)
At the box s the flair sits against a brass fitting. doubt you will find it at napa
OEM Part # 90410-06030 3.69/each
http://forum.ih8mud.com/60-series-wa...87-fj60-3.html
Old 02-23-2014, 01:01 PM
euroford's Avatar
awesome guys, that totally helps and thanks a bunch!! typical... the whole train held up due to a tiny little $3 part.
time to go do the dig through coffee cans fulls of nuts/bolts/stuff and see if i can magically find those pieces, or otherwise locate them somewhere.
if i end up hosed for today, i'm willing to bet i could find some of those up at yoda jim's. i'm also not sure about this... but i think you might need the same things for hookup to regular saginaw stuff. i might just have to bug napa and see what they got, won't hold my breath though.
i gather ya'll were looking for some overall project photos, not specifically the steering stuff. so here's the little mutant:
build thread here:
http://www.pirate4x4.com/forum/jeep-...my-willys.html
Tim M Hovey
Old 02-23-2014, 02:08 PM
euroford's Avatar
wooooo hooooo!!! doin the happy dance! since that thread had a photo of the part, i was able to go through all of the random coffee cans and actually locate these things.
Tim M Hovey
Old 02-23-2014, 03:36 PM
MountainGoat's Avatar
Club Treasurer
Nice Wescue.
Dan Kucera
TLCA# 17536
KDWJO
67 FJ40 LC Tan
95 FZJ80 LC Red
99 UZJ100 LC Black
