Old 01-14-2007, 12:44 PM
Default CB install - where on FJ40?
Just curious where you have insalled CB on an FJ40. Assuming you don't have a Tuffy with the separate stereo comparment. Pics would be great! oh, It'll be going in a '77.
thanks!
Old 01-14-2007, 01:01 PM
Here are my examples - Should explain why I could not use that double overhead compartment console I was going to use in my '76 FJ40
First pic is a crappy drawing of where I was going to mount the double overhead compartment console on my '76.
Other pics are of the CB in my '74
Old 01-14-2007, 04:03 PM
I fit my CB into the stock stereo location. Worked great.
Old 01-14-2007, 07:09 PM
Shark Bait's Avatar
I've had good luck mounting the CB bracket on the front side of my Tuffy console. I need to figure out where to mount both my CB and Ham radio in my new 40.
'12 GX460
Old 01-15-2007, 09:48 AM
Maddmatt Maddmatt is offline
Back when I had a 40 (sigh) I mounted mine vertically at the front of the factory center console. Stayed out of the way, easy to access, worked good for me.
-Matt
Matt
1996 4Runner
Old 01-15-2007, 11:26 AM
If you get the narrow Uniden, you can mount it under the dash, in between the steering column and the heater. That puts it right above your right leg, which seems like it would be annoying but is not. I snaked the mic cord around the back of the heater bu using an extension, so that it doesn't dangle on my leg.
The Uniden unit is the same one that we 80-series guys install in the dash in the ashtray hole.
I'll take a picture and post it here later.
Old 01-15-2007, 11:30 AM
Mines left of the steering column, above your left knee. It's not in the way at all, I forget the unit though- Kenwood, maybe?
Old 01-15-2007, 11:42 AM
Romer's Avatar
Romer Romer is offline
Cobra 18 II with the weather channels from NOAA
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
16 Kimberley Karavan
Old 01-17-2007, 10:29 PM
My little Uniden is mounted inside my Tuffy...all you short people are able to mount it under the dash...
Old 01-17-2007, 10:37 PM
Rezarf's Avatar
Rezarf Rezarf is offline
mine is bolted to the front edge of the stock center console.
Drew
Rezarf <><
K0RZF
My rig... "Maude"
