Old 04-03-2007, 03:56 PM
Default Carb ?'s
So...I'm still figuring out stuff on the 40. Because some of the emissions stuff is out of it (I think)...I'm not sure what should be hooked up, what should be plugged, etc.
with these limited photos, can anyone start piecing together if this is hooked up correctly? I posted some pics i think would help...
for instance, my questions are...
What should be plugged into that thing on the therm housing...where should it go?
Should the inlet be plugged on the front of the carb?
on the right side of the carb, there's a large hose coming off the outlet. It's open and routed next to the W.washer bottle. is that right? should it be plugged or routed into something?
Thanks!
