Notices
Old 02-17-2008, 07:03 PM
bigbluefj's Avatar
bigbluefj bigbluefj is offline
Honorary Canuck Member
Send a message via Yahoo to bigbluefj
Default install ARB
how long to install a front ARB locker in a 40 series????
kevin
bigbluefj
1996 FZJ80 ARB FRONT BUMPER, SLEE REAR BUMPER, OME 2.5, SLEE STEP SLIDERS, TOYO MT'S, BUMP IT OFF ROAD SKID PLATE, SNORKEL.
Old 02-18-2008, 06:36 AM
powderpig's Avatar
Are you giving the whole truck to the person or just the differential?
Old 02-18-2008, 08:42 AM
1 weekend.
16 hours of labor for complete differential rebuild/regear.
KD0FDS
Stephen
Old 02-18-2008, 08:55 AM
Rezarf's Avatar
Rezarf Rezarf is offline
AkleIke did it in a long day... maybe 12ish hours, maybe he'll chime in.
Rezarf <><
K0RZF
My rig... "Maude"
Old 02-18-2008, 09:04 AM
bigbluefj's Avatar
whole truck maybe or he said i could do just the third...
not sure...
kevin
bigbluefj
Old 02-18-2008, 09:25 AM
powderpig's Avatar
If you are just giving the diff to the guy, and he does this professionally. It should only be close to 2 hrs if he is just adding the ARB to the diff(no gear change). If he is doing gears(bearings and seals, total rebuild) as well it would be close to 3.5 to 4 hrs. To pull the diff out and install the diff in the axle with out a rebuild on the axles time is close to 3.5 to 4 hrs as well. If rebuilding the Axle then a typical axle job is any where from 8 to 10 hrs(depends on the flat rate time). Hope this helps you Kevin with your estimate. later Robbie
Old 02-18-2008, 11:52 AM
bigbluefj's Avatar
that's perfect just what i wanted to know...
thank you
kevin
bigbluefj
