Old 02-18-2008, 12:57 PM
Default Aircraft Frequencies?
So since Technician class gets you priveleges on all amateur bands 50 MHz and higher, does that mean we can call on the aircraft frequencies? It looks like their band lies somewhere in the 115-135 MHz range. I was just thinking in case you're out in the middle of nowhere sometimes the planes flying overhead are closer than the nearest repeater or ground contact. But maybe the aircraft frequencies are above 50 MHz but aren't considered to be amateur bands - or maybe our radios (in stock form) can't drop to 115 MHz? I'm still learning, but don't really know how to fish yet.
Old 02-18-2008, 01:01 PM
Shark Bait's Avatar
I've been able to listen on my VX-7R, but it does not transmit on those frequencies.
'12 GX460
Old 02-18-2008, 01:05 PM
Search.....VX-7r's are very easy to open freq's as it's just a secret code.
Old 02-18-2008, 01:32 PM
The only frequency you'd really need to be able to transmit/receive on is 121.5 - that is the international emergency frequency that pilots, ATC, etc. monitor.
I don't know the rules around transmitting on 121.5 if your not in a plane but in a life and death emergency...
Back when I was flying I use to like to listen to theCentennial tower frequency (118.9) on my ICOM HT...
Old 02-18-2008, 01:34 PM
Just 'cause you're a ham doesn't give you privileges on aircraft automatically. I think you have to actually be a pilot or ground controller.
That said, aircraft is in the VHF band, however they use AM. The VX-7R can do AM or FM on 6m, but only FM in 2m, 220MHz or 440MHz. The FT-7800/88/89 can't transmit AM anywhere. Even the FT-8900R will only do FM on 10m.
All of them (in fact most wide band RX radios) can hear AM, just very limited transmit ability of it. You'd probably have to get an HF rig that could tune the VHF band to even consider it. It might be easier to just carry an aircraft radio for emergencies. Also a fair number of pilots are hams (in fact just about every private pilot I personally know is a ham, that's odd now that I think about it) and probably will have a ham radio anyway.
Old 02-18-2008, 01:45 PM
Bighead's Avatar
Bighead Bighead is offline
As a former Air Traffic Controller, I can tell you that transmitting on one of the control freqs would be a quick way to have the FAA come down on you like a ton of bricks. If you had to transmit on anything use 121.5 like Corsair said.
Lance
2004 Land Cruiser -- OME/Slee Suspension | F/R ARB Lockers | 285/75-16 Nitto Terra Grappler | Slee Armor front, rear, sides and belly | Dual Battery | ARB Drawers
2015 4Runner Trail Edition Premium - Stock
2014 BMW R1200GS Adventure
Old 02-18-2008, 01:52 PM
Yeah, seems it would be bad to have both the FCC and the FAA ticked off at you...
Old 02-18-2008, 02:05 PM
Bighead's Avatar
Lance
Old 02-18-2008, 03:04 PM
Yep! But if you're pinned under your rig and tried everything then I'd rather have 'em POd at me than dead
Just FYI, from my experience with my ICOM HT with the rubber ducky antenna the "reach" isn't very good. For instance in the "Ranch" I could not typically hear the Centennial tower (<10 miles away) controllers talking, but I could hear the planes in the vicinity talking to the tower. Even when I used it once in an semi-emergency during a flight I could not talk to the tower until I was within ~10 miles of the airport.
Old 02-18-2008, 05:17 PM
What is it they say, it's better to be judged by 12 than carried by 6.
Keep in mind that aircraft use AM and so if you are TXing and RXing on FM, the range will seem to be very poor in both range and quality. I can hear KAPA Tower 118.9 at my house just barely in the truck. Such is the down side of AM, it attenuates quickly with range.
