Old 05-13-2008, 11:31 AM
timmbuck2's Avatar
Default 80 acting up since Moab
My 80 has been acting a little strange the last week or 2. Before Moab the truck was sideswiped and I had to replace the steering box. After a quick alignment, she was driving great. Added a 2.5" lift 2 days before Moab, the drive out was perfect, 90+MPH with no issues on I70. Drove trails for a week, everything seemed fine, late in the week I noticed the alignement was off, the steering wheel is pointed slightly to the right when the wheels are pointed straight ahead. I will take it back to Bear this week. Everything still tracks good though. Get some high pitched squealing and scraping, probably front brake pads, will check those this weekend. Now I notice a vibration or noise, especially around 30-40 MPH. Seems to increase when I give it gas, but if I let off the gas is goes away, and if I put it in neutral and give it gas, I don't hear it at all, so I don't think it is engine related. Driveshaft maybe?? The drive home from Moab was fine. Sometimes there is a slight hesitation from a dead stop...and at a stop light it sometimes feels like the engine has a slight miss every once in awhile. Just changed the oil before Moab, will replace spark plugs and air filter this weekend. Any ideas on the vibration?? Thanks 80 experts.
T
* 00 LC
* 99 Saab Convertible
* 76 Piggie
* 1996 T-100 with 396k miles
has a 2008 FJC
KDěTIM
Old 05-13-2008, 11:47 AM
Nay's Avatar
Nay Nay is offline
I'd recheck that all of your bolts are tight since you replaced control arms. Get under and take a good look that nothing is bent or loose. I'd do all of that before I started replacing anything.
Old 05-13-2008, 12:19 PM
RockRunner's Avatar
Your vibration noise may be coming from your drive shafts, actually your U joints or Cardin. i had some bad squealing and vibration coming from my truck and once I checked the U joints I found one ready to blow up.
The other stuff i would contribute to loose bolts, Like Nay said check them all and have a new alignment done but before that check your drive shafts.
Thanks T aka Tom KR0MPS
TLCA #6136
Old 05-13-2008, 12:26 PM
I would check the knuckle bearing flanges! Definitely sounds like something has loosened!
KěUBN
Old 05-13-2008, 12:48 PM
Romer's Avatar
Romer Romer is offline
Those flanges loosen up on a lot of folks.
I didn't think you made it to Moab, never saw you there.
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
16 Kimberley Karavan
Old 05-13-2008, 12:52 PM
timmbuck2's Avatar
I was there from Sunday to Sunday. Camped several nights in Bride Canyon (take a left before you hit gooney bird rock on gemini bridges road) then hoteled it. Needed some time away from people, had a few things going on. Did make it to Neil and Kim's run of Metal Masher. Ended up running Fins a couple of hourse behind you on Saturday, heard you on the CB and passed the group when you were hiking down to something. Sorry I was unavailable to help out, had some stuff to take care of.
T
* 00 LC
* 76 Piggie
has a 2008 FJC
KDěTIM
Old 05-13-2008, 01:24 PM
On these issues, from what I have read, you may want to take off and inspect the air intake tube for cracks...Especially in the "accordian" area of the tube. While you're cleaning all of the wonderful red Moab dust out of the air filter you can inspect the tube
I have the "stumble" at idle which I'm hoping between a good tune up and the MAF housing and sensor it will finally go away. It just annoys the $%^& out of me
Old 05-13-2008, 01:38 PM
Kipper's Avatar
Kipper Kipper is offline
Administrator
not sure what happened when it was sideswiped, but if the steering box had to be replaced, definitely check wheel bearings too. if they are gonna go, it's almost always after a hard wheeling trip.
Old 05-13-2008, 01:42 PM
Put a wrench on everything. Then just roll under there with your favorite frosty brew or sumthin', and let your eyes gaze at EVERYthing. You'd be surprised what you see.
Grab everything and look for any play, etc. etc.
KDěRCH
Old 05-14-2008, 09:49 AM
timmbuck2's Avatar
rolled under there yesterday, did not see anything obvious. No loose bolts, bent anything, etc. Lubed up the driveshafts, the U joints looked and felt ok, but I am not an expert. The vibration is mainly there from 30-45 MPH and the worst at 40, and only under power. I was going up a hill yesterday under relatively heavy throttle, and at 40 the vibration was bad. Let up on the gas and immediately the vibration went away...
* 00 LC
* 76 Piggie
has a 2008 FJC
KDěTIM
