Go Back   Rising Sun Member Forums > Toyota 4x4 > 4Wheeling and Event Staging Area > Rubithon 2008 planning
Old 05-15-2008, 06:43 PM
Default Things left 2 do....
Found my original to-do rubi list here so I thought it would be good to put it in a new thread....
<snip>
My list of to do's yet is...updated
Swap Bobbie for a non clicking set of Longs! Done!
finish my on board shower setup done
install subtank rrrrrrrrrrrrrrrrrrrrrrrrr
rework some of my cooling system done
3" mandrel bent exhaust done
better on-board air system done
finish my leather replacement not gonna happen by rubi
move my radio faceplate from the lower console to the new upper one (when installed) rrrrrrrrrrrrrrrrrrrrrrrrrrrr
build a rear CV driveshaft and get my rear pinion rotated up a few degrees done....well almost...
swap in OME Comp rear springs instead of the Slee 4's changed mind...maybe later...
possible Bilstein shock upgrade ^^^^^
Fabbed single drawer system beside the fridge and power box
IPOR skidplate
Deka 31 and 78 series yellow tops with National Luna dual batt system
jdm Aux A/C fan install with factory routed wiring, relay and Circuit Breaker
swapped out Christo flanged rear axles for Poly's
Installed Christo's rear locker guard
.....more to come....
KØUBN
Old 05-15-2008, 06:45 PM
Crash's Avatar
Crash Crash is offline
You'll like the Deka, Kevin.
Old 05-15-2008, 06:52 PM
I've had the 31 for around 2 months and it's awesome! The yellow Optima in the main position was becoming an issue as the Deka was consistant with voltage. Just installed the 78 series Deka Yellow for a main and all I can say is WOW!
That 31 is nuts! With the fridge running and running drills and what not off the inverter I have yet to drain it below 12.2! I figure I should be able to run a projector and we can watch a full length movie with out starting the truck! Might be pushing it if we are blending Margaritas and frothing Cappuccino's at the same time!
KØUBN
Old 05-15-2008, 07:45 PM
Convert's Avatar
Convert Convert is offline
Default Things left to do ?
WAY MORE THAN I HAD PLANED ON
I have not even had time to think about meals or camping
Better get back in the garage
Dan Reinmuth
47 Bantam Trailer/RTT
71 FJ40 project
TLCA 13269
KØVRT
Old 05-15-2008, 07:49 PM
Romer's Avatar
Romer Romer is offline
What pump are you using for your onboard shower setup?
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
16 Kimberley Karavan
Old 05-15-2008, 07:59 PM
Crash's Avatar
Uh, sounds like you like it/them already Kevin. Cool!
Old 05-15-2008, 08:34 PM
Shureflo Marine
KØUBN
Old 05-15-2008, 08:35 PM
How is the project going Dan?
KØUBN
Old 05-15-2008, 10:00 PM
Romer's Avatar
I see why
The Smart Sensor 4.0 is designed specifically for cruisers and
midsize yachts.
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
Old 05-15-2008, 10:03 PM
I see why
midsize yachts.
You got it! Actually it was all a premium R&M Specialties remote kit that I had for my 40 and never installed. Turns out a lot of hot water! Turned out pretty sweet! R&M Kit
KØUBN
