  #21
Old 08-05-2008, 09:58 AM
Ron Helmuth's Avatar
Ron Helmuth Ron Helmuth is offline
Default Schweet
Sure could have been a lot worse. Thanks for posting up what it was so we can learn from it.
I just blew a left rear axle seal and was hoping to catch it as preventative maintenance, time for me to get ahead of the repair curve.
99 4Runner SR5 V6 4x4 5 speed
LT265/75/16 Michelins at present
Fact. rear locker, OME 881f/890r springs/Nitro shocks ARB/Clear lenses/LTD. woodgrain/Sonar tails/body lift
http://www.facebook.com/album.php?ai...5&l=5795132731
  #22
Old 08-11-2008, 11:56 AM
Ah, the dreaded 3.4 spark plug kaphlewey. Not the first time it's happened. Your caution ironically was part of the cause!!!
FWIW, after I cleaned up and tweaked my 3.4, Mike Caskey told me the spark plugs were not properly tightened. Funny, I THOUGHT I put them in like I have done every other one for 30 years... Mike saved me a disaster.
Happens easy.
KDěRCH
  #23
Old 08-11-2008, 01:23 PM
Originally Posted by JadeRunner View Post
.......Oleg, replaced the plug coil and put some kind of double threaded tap in there......
= Helicoil? If so that's a good fix, you should be set for a while.
And glad to year you're back in business without much pain, proper torque on plugs is definitely not something to shortcut, they're too important.
  #24
Old 08-11-2008, 01:38 PM
JadeRunner's Avatar
Cruise Moab Co-Chairman
Happens easy.
Bill, can you clarify this a little for me. Blue thread lock stuff and a torque wrench to the proper specs is still all i know to do. Or i gues I could do like Oleg does just hand tighten till it's real tight.
Scott Yoder KD0DHP
  #25
Old 08-11-2008, 01:44 PM
? I always have just tightened the spark plugs until I feel the crush sleeve yield, and then a bit more ? If they're threaded straight and the socket is straight on the plug then I would think you'd really have to be yarding on the wrench to get the head to strip out...
  #26
Old 08-11-2008, 03:08 PM
BLUE THREAD LOCK on sparkplugs??!?
No way, d00d. Anti-seize where steel threads into aluminum. Otherwise the threads get damaged, or the plug seizes, or both. Anti-seize and a torque wrench.
Mine were loose because I followed Oleg's method without using Oleg's brain and fingers...
KDěRCH
  #27
Old 08-11-2008, 03:10 PM
More than one 3.4 has kaphlewied a spark plug right out of the head. Not sure why. Loose obviously does not help... And cross threading is a lot easier to do than that. Maybe part of the problem is that when the threads start to feel tight you think the spark plug is getting tight, and its not. And the 3.4 plugs are waaaaay down deep in a hole between the cams.
KDěRCH
  #28
Old 08-11-2008, 04:32 PM
TOTONKA's Avatar
TOTONKA TOTONKA is offline
Thumbs up
My V6 with only 110k has let me down big time. I am so bummed out, I thought my Runner had many more dependable miles on it. WTF!!.
I had 2 engines replaced by toyota under warranty.
I noticed the problem every time i started up the motor (SMOKE), puffy.
The MECH said Radiator fluid was leaking through the seals causing electrolysis.
They took care of it NO PROBLEM.
Toyotas are top quality
  #29
Old 08-12-2008, 10:04 AM
Eh? Would that be a head gasket failure by any other name? TWO motors replaced? What model and year?
KDěRCH
  #30
Old 08-12-2008, 10:13 AM
lurking along-I can find in a manual somewheres-what is the proper torque specification please for the 3.4 V6 sparkplugs? I may as well get this handled before I learn the hard way
-I presume all 6 to be the same torque setting but have been wrong before.
