Old 09-29-2008, 01:36 PM
trucruiser trucruiser is offline
Default Hg 2f
I am replacing the headgasket on a 2f out of an 87 fj60 and had the head checked, They said it was off by 6 thousands of an inch in the middle. Does the head have to be shaved or and if so can it be shaved that much?
Thanks
Old 09-29-2008, 01:59 PM
Thanks
2F head decks are thick! Shaving it .008" will raise your comp 1/2 a point in compression ratio and you will have no durabliity issues. The rowdy F in my 40 had the head shaved .008 and the deck shaved .004! Even with Chevy valves, custom cam and forged pistons the stock valve reliefs were deep enough!
Old 09-29-2008, 02:38 PM
Thanks for the quick reply. Looks like off to the machine shop.
Old 09-29-2008, 02:56 PM
do it or you will blow another head gasket and they are a pita to deal with.
Old 09-29-2008, 06:12 PM
powderpig's Avatar
I thought that Mark W said in a old article that you could shave up to .100, which is quite a lot. But even when I did Steve (crash) head for his rebuild, I believe that we went .060 on that with not much ill effects.
So UB are you thinking that .080 is what you may of done, I do not think that shaving .008 will bump the compression 1/2 of, but think that .080 will.
Old 09-29-2008, 09:26 PM
I believe you are right sir! When I typed that I thought 8/1000 seems pretty light but 80/1000 seemed like too much. Thank you Sir Robbie for keeping me in check!
