Old 01-14-2009, 01:13 PM
60wag 60wag is online now
Default 80 power steering hoses
There are two hoses on my 80 that appear to be leaking. There are behind the radiator near the battery. I think they are both hoses for the power steering. They both look like high pressure hoses with crimped fittings on the ends. Why would there be two high pressure hoses? The cooler is on the low pressure side of the circuit isn't it?
Should I replace them with OE hoses or is NAPA ok? Any special tips to doing the replacement? TIA
Old 01-14-2009, 01:58 PM
Romer's Avatar
Romer Romer is offline
There is one Highpressure hose and a return Hose. The Highpressure can appear as two depending on how you look at it as it goes down almost the radiator and then is a metal loop before coming back to the Gear box.
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
16 Kimberley Karavan
Old 01-14-2009, 03:47 PM
That makes more sense. Thanks.
Old 01-14-2009, 05:44 PM
Convert's Avatar
Convert Convert is offline
Look closer it may be the pump
Dan Reinmuth
47 Bantam Trailer/RTT
71 FJ40 project
TLCA 13269
KØVRT
Old 01-14-2009, 05:50 PM
if it is the pump, do the hoses while you're there.
Old 01-14-2009, 05:53 PM
Romer's Avatar
Bruce, maybe this will be helpful. Pics of the hose and pump
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
Old 01-14-2009, 07:23 PM
Ken, I not seeing the picture.
I was just digging through the electronic version of the shop manual. What a pain. I hate having to open a zillion different PDFs only to find there isn't an assembly picture tha actually shows the system layout and hose routing. I know its pretty simple - the pics I have looked at look oddly similar to an FJ60. I just need to actually open the hood and get busy - I hate working on cold trucks, especially when it involves greasy leaking hoses.
Do I need to talk to Jerry at Boulder Toyota to get the Rising Sun deal on parts? TIA
Old 01-14-2009, 08:09 PM
I just found Ken's faq on MUD. Very complete, just what I was looking for. Now I've got my fingers crossed that I don't need a pump as well.
