Old 03-06-2009, 05:07 PM
Default works well.
When I put this together, I should have grabbed a quick-disconnect. (I did that on my FJ60) - so I could easily take it off. The other thing I'd do differently is get a steel whip...not the fiber glass. I've already ripped the little red rubber cap off this one and it doesn't give very much when under low branches.
As far as receiving/transmitting - works almost as well as when I had little mag-mount stuck on my rack.
That looks pretty good Shawn. Nice and high, and will work with the hardtop on or off.
Just punch a couple of holes in a tennis ball and slide it over your antenna and duct tape it in position to keep it from whacking your top.
Old 03-06-2009, 05:21 PM
Disappointing
Use a lip mount off of the hood, and mount it here (3):
Here's a link to a stainless steel mount for less than $10.
Name:  CB lip mount.jpg
This will give you good reception and broadcast ability. Avoid mounting the antenna where it will have a lot of parallel metal surface.
Old 03-06-2009, 05:32 PM
mount it on the front bumper. For god sakes don't drill anything into that body
LETSROLL's Avatar
LETSROLL LETSROLL is offline
Hulk,
Does the lip mount require it to be screwed into the hood underneath? It looks like you'd have 4 holes to tap?
LETSROLL
John Glidden, Boulder
TLCA#19430
1996 FZJ80 Locked & Lifted, ARB Front, Slee Dual Swing Arm Rear, BFG ATs on FJC Wheels, Speski Barrier
2005 Subaru Outback XT
1997 FZJ80 Collector Edition
Old 03-06-2009, 05:41 PM
Originally Posted by LETSROLL View Post
Hulk,
I was recommending what Hulk said also. This mount only requires 2 holes and is re-enforced. It would be attached to the apron, not the hood.
That works too.
Old 03-06-2009, 05:45 PM
YEAH!!! totally! something tells me I have an old, slimy tennis ball in the back yard. "Carver! Come!! Get the ball" "heh, heh...mine now".
Old 03-06-2009, 05:47 PM
Default Yeah! what wes said!
Your 40 is sooooooo nice...there's no way I could drill holes in that nice of a cruiser. But that's me. After looking at the Incredible 40 stretch...I realize everyone is different and has a different idea of what they want to do with their Cruiser.
Old 03-06-2009, 05:54 PM
Beater's Avatar
Beater Beater is offline
OMFG don't you even put a hole in that.. mount it to the spare.. I'll make you a frickin bracket before I'd let you cut that body
j
john (johnny) henley
Old 03-06-2009, 05:58 PM
LETSROLL's Avatar
I think I like the idea of mounting it to the spare tire bracket like MDH33, but how does the wire get inside the rig? With hood mount option or how I was going to do it, the wiring looks simple..
LETSROLL
TLCA#19430
