Old 12-03-2017, 09:59 PM
Default Is my trans going out?!
Mileage 192,000 miles now. My transmission has started grinding loudly when going up at highway speed up a steep pass - like up from Georgetown to Downieville. It has a harsh grinding sound along with a mechanical shudder and rattle.
I have had episodes that my Reverse gear is not working at times. Those two things have got me worried about it. Are these signs of its imminent demise?
P.S.
I should also add that I was not towing anything at the time. I've had two passengers with me and some light gear. I plan on checking the ATF fluid level and color tomorrow and I'll report on that.
James DePaul
Old 12-04-2017, 11:02 AM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
James...have you done any service to your tranny? Dropped pan to check screens? Full fluid exchange using "Rodney" or other?
What about your T-Case? Are you sure the growling is coming from tranny? These transmissions rarely fail, so this is why I question.
Paul
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
Old 12-04-2017, 12:05 PM
if you end up needing one, i have one i bought from robbie that i'm not going to use now. i'll sell it for what i paid
Old 12-06-2017, 08:37 AM
@Paul - no, I have not done any transmission service work on it.... it could be the Transfer Case, I don't know. The transfer case has signs of being serviced in the past. Yes, I should drop a pan on it and change the trans fluid in it to check its condition. What is the "Rodney" you mentioned?
James DePaul
Old 12-06-2017, 09:31 AM
rodney is an australian who has a company that specializes in trans upgrades. wholesale automatic transmissions, iirc
Old 12-06-2017, 11:04 AM
ToyodaTocco's Avatar
ToyodaTocco ToyodaTocco is offline
See post # 4
http://www.risingsun4x4club.org/foru...t=rodney+flush
Bill
TLCA #23154
1984 Toyota Pickup "The Geisha"
1994 FZJ 80 "REDRUM" All work and no play makes Jack a dull boy
