Old 12-01-2017, 05:21 PM
skennedy82's Avatar
skennedy82 skennedy82 is offline
Default 1994 4runner transmission torque specs
Anyone know the torque spec for the reverse shifter sensor? I know it seems trivial but it's leaking and I just replaced the copper washer... Thanks
Old 12-01-2017, 05:54 PM
Is it a stick or auto? V6 or 4 cylinder? I'm assuming V6 so R151F, which is 27 ft-lb. On the W56 it's 30 ft-lb. Not sure about the A340, though. If it works like the manual transmissions then it's probably about the same torque.
