Old 09-14-2016, 11:33 PM
Default K&N Air Filters
Need a new filter for the 100, any reasons to NOT run a K&N? I'm wondering between our dust, dirt and Utah silt if a reusable filter is an advantage or just good marketing hype?
Old 09-15-2016, 07:09 AM
I ran a drop-in K&N in the '91 and noticed more dust in the intake tube. Went back to the stock Toyota. I'm not sure I trust the K&N. YMMV. In applications like Red Chili with the pre-filter foam over the cone maybe they are better, couldn't say.
Old 09-15-2016, 09:02 AM
Firetacoma Firetacoma is offline
Not K&N, but I ran a TRD reusable air filter on my old '99 Tacoma and got a LOT of oil and dirt gumming up my MAF sensor.
Old 09-15-2016, 09:12 AM
ttubb's Avatar
ttubb ttubb is offline
I had to replace the MAF on a 4Runner due to gumming up after using K&N filter. Never again.
KA7TLT - TLCA 13015
Old 09-15-2016, 10:13 AM
Crash's Avatar
Crash Crash is offline
Used the K&N for a couple of years and found more dust inside the 62's intake tube than stock paper or oiled foam. for the 100 I plan on sticking with the OEM.
K0OMC
Old 09-15-2016, 10:59 AM
Same. Got a dry filter for the 4runner, but it was so loud I got rid of it and went back to stock.
KandN gummed up the MAF in a year and let in a ton of dust. No bueno.
Old 09-15-2016, 11:25 AM
coloradobound's Avatar
coloradobound coloradobound is offline
I run afe dry media. Filters well and no oil to gum things up.
http://afepower.com/afe-power-31-100...y-s-air-filter
2002 Tacoma DCab TRD, OME suspension, 1" Daystar Bodylift, ARB front bumper, Lightforce 170's, 20" led light bar, blacked out HID bixenon projectors, Slee Sliders, 33" Yoko's on 5th gen 4Runner wheels, TRD supercharger, exhaust, and trans cooler.
to do: snorkel, ditch lights on Cbioffroadfab brackets, flush mount lights in new rear bumper, rock lights, new retrofits in headlights, ARB fridge mounts in bed w power, hids in LightForce (or arb led knockoffs)
Old 09-15-2016, 11:36 AM
TheHoneyBadger's Avatar
The Red Chili no longer has that bulky foam pre-filter. But it seemed to work ok? Squishy! should chime in on wether or not he's noticed a difference now.
I ran a K&N for years without a pre-filter. I wasn't really happy with the dust situation. So I ordered a light weight pre-filter from K&N for my specific filter size. I think it was $15. But it's definitely worth it. It catches all the dust and what not. It's easier to clean and cuts down on the need to clean the actual filter so often.
Now this is of course on a cold air intake with a cone filter. Factory intake boxes with the square filters are a whole other deal.
Before I went to the cone filter I did run a K&N in my factory intake box. But I didn't run it long enough before I switched to really know how it worked.
I never looked for them, but there may be pre-filters for the square drop in filters. If there are, definitely get one.
Travis R.
TLCA #22468
I would rather walk than drive anything that's 2WD.
Old 09-15-2016, 11:40 AM
I loathe cleaning K+N filters (don't want to run oil into my septic system, and cleaning them with cold water in the yard with a garden hose doesn't work). Also, many rants against them in the Ford Powerstroke world - turbo 'dusting' due to dirt passing through.
I would get a Denso from Rock Auto (cheap) and run with that.
Old 09-15-2016, 12:14 PM
biggest problem is over oiling them. I ran one in my old Dodge Ram 1500 and it was great. I got better MPG and noticed more power. Subaru Turbo no difference.
In the cruiser I only run OEM as everyone knows on MUD, failing to do so will cause the end of the world.
