Old 09-14-2017, 09:52 AM
smslavin's Avatar
smslavin smslavin is offline
Default shop recommendations for gearing/locker install
I've started looking for quotes on 4.88s and a rear locker install. I've checked with two shops here in Denver and there's a $2300 (4400 to 6700) difference. Both are including a major install kit (bearings, seals, etc) but I have not included the compressor. I'll do the compressor myself as I'm not sure yet where I want to put it. Does anyone have a shop recommendation? I'm willing to drive a bit if the shop is reliable, the work is good and the price is reasonable. I don't feel comfortable in tackling this one on my own.
Old 09-14-2017, 01:01 PM
CardinalFJ60's Avatar
Default robbie
Robbie's the only person I let touch my cruisers.
Old 09-14-2017, 09:50 PM
jps8460's Avatar
jps8460 jps8460 is offline
Commander
Did you check out slee?
The rear is straight forward, but the front is kind of a PITA and requires some finesse and an oven you're willing to have smell like gear oil.
4400 seems very reasonable, boarderline cheap. 6700 seems a bit on the high side.
I would definitely pay more for someone that is familiar with the front diff. It's very easy to mess up the front case.
Jackson - KD0VZS - jackson@jp4wd.com
2008 mall cruiser - aka Black Beauty - ramps good
1994 fzj80 - nearly 500,000 miles young - thrasher rig
84 FJ60 low gears, locked, fun, rebuilt-2FE - gone
1995 Toyota Camry, 4x4 at heart
"In God [i] trust. All others, bring data"
-E. Deming
Old 09-14-2017, 10:07 PM
Romer Romer is offline
Like Jackson said. The rear takes shimming and its expensive to figure out you haven't done it right.
Robbie did my 40, Slee did my 200
ATLR might be another good option
Old 09-15-2017, 10:29 AM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Robbie or Slee. My Robbie-done nitro 4.56ss are doing great two years later.
Unlike what Romer said, no shims here. I opted to use Toyota crush sleeves vs solid spacer with shims. Installer opinions will vary.
You want someone familiar with the kits, parts, and quirks.
Old 09-15-2017, 03:20 PM
jps8460's Avatar
Commander
Both the 10.5 (tundra) and the 9.5 elocker use shims for CB preload/backlash and for pinion depth (I think this is what ken was getting at).
I believe you are referring to the pinion bearing preload. I am a fan of crush sleeves unless you can machine the solid spacer to spec. The 10.5 uses a solid spacer from the factory though.
The front diff is the funky one in this case. The front case is a bit fragile and takes experience to get it right.
-E. Deming
Old 09-15-2017, 06:03 PM
smslavin's Avatar
On my list. Just need to call.
Forgot about ATLR. He's done good work for me in the past.
Appreciate everyone's input.
Old 09-15-2017, 06:49 PM
Crash's Avatar
Crash Crash is offline
Now that Jackson has come out of the diff closet, he should be added to the list of reputable builders of Toyota diffs. I'd trust him with my stuff.
K0OMC
Old 10-20-2017, 08:13 AM
morgan's Avatar
morgan morgan is offline
Sorry to dig this up from a while back but did you get the gears/locker installed on your Tundra?
Thought I was the only one actually wheeling a full size rig, good to know there are others
Wil
2013 Toyota Tundra
2014 FWC Hawk
TLCS #23727
http://expeditionportal.com/trans-am...f-the-rockies/
Old 10-20-2017, 05:46 PM
smslavin's Avatar
not yet. still putting pennies away. it's the last big ticket item, for now, but i'm trying to button up some smaller projects first.
