  #111
Old 03-17-2016, 01:21 PM
Brucker Brucker is offline
Originally Posted by Brucker View Post
Ok, will repost
Better? I redid the last two posts...
  #112
Old 03-17-2016, 02:49 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
I see it all. Looks killer man.
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
  #113
Old 03-18-2016, 09:43 AM
Yup better now. Thanks for sharing!
  #114
Old 04-13-2016, 01:06 AM
Slow on the updates as I am still experiences some computer issues and don’t feel like trying to update from a phone.
Works continues as we focus on the front shock hoops. The hoops themselves will be tied into the front bumper and the A pillar body mount, as well as to the frame like normal. They will also be tied into the A pillar cage mount. This will not only add strength to the frame, but add more to the bumper and the entire front half of the chassis.
A look at the factory shock mounts:
Cut the stock mounts off and cleaned up the frame rails:
Before we cut the inner fenders to make room for the hoops, we clean up the Trail Gear shock hoops. As the arrived:
Cleaned up a little:
***photos missing***
Cut the inner fenders to clear the shock hoops, then tack welded them into position using mock up shocks.
  #115
Old 04-13-2016, 01:09 AM
The A pillar body mount sits directly over the front spring shackle mount. The new longer shackles can come into contact under great articulation, and are known to get snagged against rocks when wheeling, so we remove a couple inches off the lower part of the mount.
As they looked stock:
Cut and cleaned up:
Then cut the front inner fenders to make room to tie the hoops into the front bumper:
Added a tube to tie the hoops into the body mounts
And another to tie into the front bumper
  #116
Old 04-13-2016, 01:12 AM
Layout the bolt on mounts for the bumper to keep it removable.
Removed the bumper to drill and tap the bumper
Finish the layout on the bumper and center punch the holes to be drilled and tapped. Clean up the welds for the mounts to sit flat. Then drill and tap the holes and fasten the mounting plates to the bumper.
  #117
Old 04-13-2016, 01:13 AM
Mounted the bumper once again and tack welded the tubes to the mounting plates:
We modify the center tube gussets that came with the hoops. They are angle cut on the ends to opposing 45* angles. But neither end is correctly notched for round tubing. So we notch on end of each of the gussets and tack them into position
  #118
Old 04-27-2016, 01:52 AM
Even with as clean of a body as this 4Runner has, it still has some issues with rust. Same old spots, the rear fenders. Now is the best time to get after them and make this truly a clean rig. Here is a look at the rear fenders. Driver's side:
Passenger side:
We start by taking the paint off the areas in question to get an idea of how much we will actually need to cut out and replace. As you will see the rust was a lot worse than it looked. As usual the paint actual hide a lot of the problem areas.
  #119
Old 04-27-2016, 01:55 AM
Removed about an inch from the rear fenders. This removed the majority of the rust in question, except for the bad areas in the lower corners. We will deal with those in a bit.
Then we prepped the area more in order to cut and fold the fenders in order to enlarge the wheel openings a bit.
Then made a series of vertical cuts to start the cut and fold process.
And start the folding process:
Once finished, not only will all the rust be removed, the wheel well will get a bit more clearance from the tries. About an inch and a half extra to be exact. Here is a measurement from a stock 4Runner rear fender:
And with the folded fender now:
