  #561
Old 01-13-2015, 04:52 PM
Resurrecting an old thread but I must confess...
The 100 series kills it in the snow. Hands down its the best snow vehicle I've ever driven. Just wow.
  #562
Old 01-13-2015, 05:57 PM
OilHammer's Avatar
That may depend on the year. Mine has a nasty way of beeping at me when I play and try to drift it, whereas the 80 would powerslide quite nicely. Wiring in a defeat switch for the traction control and stability control would be nice at times.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
  #563
Old 01-13-2015, 06:42 PM
Traction control!? I'm partying in the snow like its 1999!
  #564
Old 01-14-2015, 10:31 AM
OilHammer's Avatar
Not just traction, stability control. Even if you can manage to spin all four tires and keep the traction control from pulsing wheels, the stability when swing in as soon as the rear end steps out and nip it. It's amazingly effective, but annoying when you have a nice wide road and want some fun. All of my other cars have had a switch to kill it, and I'm sure there's a way to on these, but I've never looked into it. Eventually I will, but kinda like the back shelf project I have to wire up a Arduino relay board to bypass the factory NAV and be able to run an ipad for everything. No time soon.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
  #565
Old 01-14-2015, 12:32 PM
Fishy's Avatar
Fishy Fishy is offline
Locking the center diff will allow you to drift and slide without VSC overriding your input. It still corrects itself, but does not cut power AND apply brake which allows you to control the slide.
Stan
UZJ100 (Non-White Edition)
OutdoorX4 Magazine Staff
100s in the Hills Co-Director
  #566
Old 01-14-2015, 05:39 PM
OilHammer's Avatar
I don't think I've ever locked it intentionally. Even on the 100's in the hills, I forgot to do it. Meh....
Might be worth trying, but don't want my diff to barf gears either.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
  #567
Old 01-14-2015, 06:08 PM
Fishy's Avatar
If you don't lock it, it doesn't lock itself. Even when you pull down into 4lo.
There is no reason NOT to lock it when you go offroad. And, by not ever locking it, it causes the actuator to seize up. You should at least lock/unlock a few times per year.
Stan
  #568
Old 01-14-2015, 06:18 PM
Fishy's Avatar
Probably similar to the 80, but if the CDL hasn't been locked in a long time, it will probably lock but not unlock. Stopping and backing up about 10-15 feet and pulling forward again should do it.
Stan
  #569
Old 01-14-2015, 06:24 PM
Romer Romer is offline
the difference with the 80 is that when you go into low, the CDL automatically locks. Learned on the 100 that ain't so like you said. Don't think its the same on early 100's though
Did black bear pass in Low without being locked, figured it out near the end
  #570
Old 01-14-2015, 06:40 PM
Fishy's Avatar
Correct.... The 98-99 auto locked the center in 4lo. The pin7 mod fixes that.
I make it a point to tell everyone to be totally unlocked for black bear so you can easily make the hairpin turns without binding.
I had to remind a lot of folks when I spotted on BB for the FJ Summit.
Stan
